84
[SURVEY INSIDE] Oxygen OS Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. Fatih Aşkın
    Gingerbread Jun 6, 2020
    fatih.askn2 and rahulhere_ like this.
  2. renz2ho
    Froyo Jun 6, 2020
    renz2ho , Jun 6, 2020 :
    Someome experienced here lagging in input box while doing search in any browser or application. if i will delete the text it will get hung deleting the text and few minutes will back to work again and i noticed my text that i input are already erased all. Anyway just to informed not happened all the time. But i think its a bug.
  3. ASCHENTE_V
    Jelly Bean Jun 6, 2020
    ASCHENTE_V , Jun 6, 2020 :
    Did you try to clear cache of you keyboard/erase its data to delete updates? If that doesn't help, I would have made a backup and formatted.
  4. Q1574596274246 likes this.
  5. harshil1903
    harshil1903 , via OnePlus 7T , Jun 6, 2020 :
    The Dark theme issue might be resolved by restarting your phone. When I switch from dark to light theme and then back to dark, the notification panel often changes to greyish rather than pitch black. But restarting helps bring it back to pitch black.
    BENJZ89 likes this.
  6. J1585090666932
    Froyo Jun 6, 2020
    J1585090666932 , Jun 6, 2020 :
    Yes, I have that but I think it's getting stuck from my One Hand Cursor activation areas. I now set it to disable the activation areas (before I had it to move above) and haven't noticed the issue yet. I only seem to be having this issue when the activation zones were overlapping with the keyboard (unless I was really unlucky).
    Do you have this or other similar apps with activation zones?
  7. J1585090666932
    Froyo Jun 6, 2020
    Unfortunately a reboot didn't resolve it on my side. my panel is grey, and the status bar itself black. I haven't noticed this in previous versions, not sure if it's something new or I just didn't see it but now I cannot unsee it and I don't like it :D
    As far as the system size - it's taking up 30GBs on my device as well after a complete wipe and clean reinstall. I find that to be ridiculously large, I have no idea where that size is even coming from? Even full Windows 10 doesn't take as much space on a computer.
  8. harshil1903
    about the 30 GB of storage, it's because OnePlus 7T has A/B partitions for seamless updates. It helps in keeping a backup of old OS while updating in case anything goes wrong with the new update and also allows you to use your phone while Update is being installed.
  9. Fixxer
    Fixxer , via OnePlus 7T Pro , Jun 6, 2020 :
    What's the point for OnePlus employees (bug hunters) to ask for your feedback and logs, if they aren't coming back afterwards with any reply or insights on the issue? 🤔
    Maybe the need more than 1 week to reply back. Do you guys receive feedback after uploading and sending logs?
  10. Sooraj Pullela
    Cupcake Jun 6, 2020
  11. igorduarte
    Cupcake Jun 6, 2020
    igorduarte , via OnePlus 7T , Jun 6, 2020 :
    Hello guys,
    I have a 7T global version. Im running the 10.0.11 stable and im trying to go beta 4, but when I try to uptade it says that the version is lower and i cant down grade for safety reasons.
    I already used once beta 4, but now it says that.
    Any help?
    Regards
  12. zer0se7en
    Ice Cream Sandwich Jun 6, 2020
    zer0se7en , via OnePlus 7T , Jun 6, 2020 :
    I guess it depends on what problem or issues you were reporting. Some of those issues needs to be reproduced by the devs in order for them to know why it happened and how to fix it. It's always been like that even on a non-OnePlus community feedback section. That it takes time for anyone to reply.
  13. zer0se7en
    Beta 4 is older than 10.0.11. Just to be safe, wait for the next beta if you want to jump ship on the Open Beta program.
    dim_dais likes this.
  14. igorduarte
    Cupcake Jun 6, 2020
    Thanks bro,
    I was already on beta. I Just wanted to try the stable one but now i cant go back to beta.
    I will wait then until beta 5
    thanks bro
  15. Fixxer
    Yeah, I understand that. I was just asking for others experience because I don't have any other benchmark to relate to.
  16. Dipto79
    GarikOnePlus likes this.
  17. ASCHENTE_V
    harshil1903 and Donald Nice like this.
  18. Donald Nice
    Honeycomb Jun 6, 2020
    Donald Nice , Jun 6, 2020 :
    Have you flashed a global build manually? If yes, there is your answer
    Sooraj Pullela likes this.
  19. Sooraj Pullela
    Cupcake Jun 6, 2020
    Sooraj Pullela , Jun 6, 2020 :
    Yes, actually i flashed it using oxygen updater. What should i do now?
  20. BENJZ89
