84
[SURVEY INSIDE] Oxygen OS Open Beta 5 for the OnePlus 7T and OnePlus 7T Pro
  1. Fatih Aşkın
    Gingerbread Jun 19, 2020
  2. Fnaticmeemo
    Eclair Jun 19, 2020
  3. ngydat
    Lollipop Jun 19, 2020
    ngydat , Jun 19, 2020 :
    That explains why you can't have the update. Either you use the stable version of Oxygen (which you're using) or you use the beta.
    You can't have both.
    See that as a tree with 2 different branches. Those 2 branches grow at different rhythm but they never cross each other (from the stable branch, you'll never have the update notification for the beta. Same the other way around).
    The only way you could go from the stable to the beta (and vice-versa) is by flashing the related update.
    But I wouldn't recommend to do it if you're unfamiliar with the process
    razaransari18 likes this.
  4. Pradyumn.0.
    Eclair Jun 19, 2020
    Pradyumn.0. , Jun 19, 2020 :
    I downloaded the OB 4 since OB 5 is not yet available on the Oxygen OS website, it's showing this
    Please Help.
    Thank You
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 19, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 19, 2020 :
    It means you need beta 5 not beta 4. Can only flash upgrades.
    Sources that provide links faster than Oneplus homepage...
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    Or
    Oxygen Updater (not an official app)
  6. Raghava.dasari
    Donut Jun 19, 2020
  7. Raghava.dasari
    Donut Jun 19, 2020
  8. Dipto79
    Dipto79 , via OnePlus 7T Glacier Blue , Jun 19, 2020 :
    Bug : After apply OnePlus 7t live wallpaper it's shows dark , no one-handed mode, weather app settings option black
    I think OnePlus showing respect to THE BLACK 🖤🖤
    We need OB6
    Bobby.K and Raghava.dasari like this.
  9. Sachink4980
    Eclair Jun 19, 2020
  10. SAGAR8494
    Cupcake Jun 19, 2020
    SAGAR8494 , via OnePlus 7T , Jun 19, 2020 :
    I have a problem in my screen will colour issue. for red colour all apps and photos is visible in brown or black colour can any one suggest the solution
  11. Udit2508
    Udit2508 , via OnePlus 7T , Jun 19, 2020 :
    no its not. battery life is decreased and charging time increased. i want to submit logs but have a few question on which nobody is guiding.
    Niek Kant likes this.
  12. Fixxer
    Fixxer , via OnePlus 7T Pro , Jun 19, 2020 :
    I've submitted logs and provided all the necessary feedback, but I haven't got any reply afterwards, exactly on the same matter, slow charging speed.
    And this comes after I've been specifically asked to provide feedback and logs by an OnePlus employee /bug hunter.
    I eventually found out myself that an app was constantly overflowing my cpu and therefore higher charging times and worse battery life. Everything reverted to normal after I've uninstalled the respective app.
    Niek Kant and Swejuggalo like this.
  13. Swejuggalo
    Easy to blame the charging... Harder to see why it behaves the way it does. Charging speed can't be good with a high draining app. Both total charge speed and thermals go nuts.
    I wonder how often users that complain on charge speed have app issues... My guess is pretty often.
    iamabhijeetpanda and Fixxer like this.
  14. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Jun 20, 2020 :
    You are right brother charging speed doesn't depend upon any app.
  15. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Jun 20, 2020 :
    Can you tell which app is it ?
  16. s1amson
    Cupcake Jun 20, 2020
  17. Fixxer
    Gingerbread Jun 20, 2020
  18. balajiinkulu
  19. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 20, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 20, 2020 :
    My point was that one misbehaving app creates a problem. It could drain battery fast and create heat.
    The end result is charge speed - drain - limited speed due to extra heat = real speed.
