83
[SURVEY INSIDE] Oxygen OS Open Beta 5 for the OnePlus 7T and OnePlus 7T Pro
  1. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 28, 2020 :
    I'm not sure of the problem.... You can't use both tap to wake and double tap at the same time?
  2. Advvinay
    Gingerbread Jun 28, 2020
  3. linus.lobo
    Cupcake Jun 28, 2020
    linus.lobo , via OnePlus 7T , Jun 28, 2020 :
    My phone restarts by itself when kept on charging, it restarts after it reaches 100 percent. This doesn't happen every time, but it has happened at least 4-5 times.. Anyone else facing this issue?
  4. iampm
    iampm , Jun 28, 2020 :
    The instant games feature is a great addition to the game space but it would be cooler if those instant games could also be played offline after a minimal download or something like that [e]1f60a[/e]
  5. C1593387754936
    Cupcake Jun 29, 2020
  6. AzretKhan
    Froyo Jun 29, 2020
    AzretKhan , via OnePlus 7T Pro , Jun 29, 2020 :
    this is not a problem, but please make it possible for the global firmware to turn on the screen with one and two touches, so that both options always work in the global, there is only one option
  7. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 29, 2020 :
    Since it works in betas on 7 series (not sure about stable) and is standard on 8 series I can only assume that waking up the device with both touch to wake and double tap will work on 7t series too (works now in beta but not stable?)
  8. C1593387754936
  9. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 29, 2020 :
    The main idea with Hotspot is to share your mobile data with other devices. While doing so you can use mobile data just like normal.
    While some allow sharing WiFi via Hotspot... In most cases I'd say... Why connect via the phone if you can connect directly to the already existing WiFi?
    I'm sure there are cases that need it... But it's not the main idea behind it.
  10. scorpion161986
    Eclair Jun 29, 2020
  11. ashwyn7
    Eclair Jun 29, 2020
  12. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Jun 29, 2020 :
    What is it.. please in English...
  13. BeingIncog
    Nougat Jun 29, 2020
  14. AzretKhan likes this.
  15. AzretKhan
    Froyo Jun 30, 2020
    AzretKhan , via OnePlus 7T Pro , Jun 30, 2020 :
    Yes, there are in the latest beta versions, but not in stable. I hope to appear in a new stable OОS.
  16. YogeshSinghSammal
    Eclair Jun 30, 2020
  17. ananyr
    Gingerbread Jun 30, 2020
