84
[SURVEY INSIDE] Oxygen OS Open Beta 5 for the OnePlus 7T and OnePlus 7T Pro
  1. AshikOneplus
    Cupcake Jul 1, 2020
  2. L1571448340101
    Donut Jul 1, 2020
    L1571448340101 , via OnePlus 7T , Jul 1, 2020 :
    Hello Team, Plz add dual channel network acceleration (That we can use Mobile data and WiFibat same time) or dual wifi connectivity to boost downloads amd browsing speed plz push the update if possible.
  3. harikirankoduri , via OnePlus 7T Pro , Jul 1, 2020 :
    This option is already available in settings- wifi & network
  4. Rishabh1525
    Donut Jul 1, 2020
  5. L1571448340101
    Donut Jul 2, 2020
    L1571448340101 , via OnePlus 7T , Jul 2, 2020 :
    I am using my one plus 7t in india it may has defferent software than other regions.
    Not yet available.
  6. BENJZ89
    Gingerbread Jul 2, 2020
  7. SrTepeTM
    Cupcake Jul 2, 2020
    SrTepeTM , via OnePlus 7T , Jul 2, 2020 :
    This case is easy to solve, if you go to the Play Store, in Top Popular, just below the Search bar, it will say, "Top Pupolares: For Tablets", the procedure is easy, you must access the Developer Options, Change the DPI to 320, delete the data from the Google Play Store and restart the Mobile, after this enter the Google Play Store, update all the apps that appear to you, (sometimes they take time to appear, be patient) and after that, you can put the DPI you choose again, the certain ones are 411.
    Greetings, I hope I have helped you.
  8. AshikOneplus
    Cupcake Jul 2, 2020
    AshikOneplus , via OnePlus 7T , Jul 2, 2020 :
    No problem remains same
  9. SrTepeTM
    Cupcake Jul 2, 2020
    It is rare since all the users that I have found with this problem, was for that reason, check that in the Top Popular section of the Google Play Store it does not appear for Tablets, and send Capture, to ensure.
  10. AshikOneplus
    Cupcake Jul 2, 2020
    Thank you. It worked.may i know the root cause of the problem?
  11. SrTepeTM
    Cupcake Jul 2, 2020
    In our case and that of all of us who have been able to solve it with the Process indicated above, it was a problem of recognition of the Google Play Store, since it recognizes our device as tablets, either for DPI or for another reason.
  12. Nishant@53
    Cupcake Jul 2, 2020
  13. chiraggohil
    BENJZ89 likes this.
  14. bennyrose
    Froyo Jul 2, 2020
  15. karthikeyans1977
    Gingerbread Jul 3, 2020
    karthikeyans1977 , via OnePlus 7T , Jul 3, 2020 :
    While receiving incoming calls, the company name from stored contacts (when you store name, no. and company in respective fields) is not displaying.That feature is available on OP 5 with the latest update. When will it come to OP 7T? Been asking for this feature for nore than three years now and in between switched to iPhone just for this and returned back to OP. Glad to see it is being included as a feature for OP 5 users but will be great if it can be made available for everyone else as well.
  16. Rajesh Shiva
    Rajesh Shiva , via OnePlus 7T , Jul 3, 2020 :
    I think it's not possible, you have to flash rollback build and then update the latest version via OTA, may be u can if the stable version is latest than the open beta 5, which is yet to be released (try if warning shows of boot failure, avoid this method), for now u have to do it via rollback build only
  17. N1576935632292
    Donut Jul 3, 2020
