84
[SURVEY INSIDE] Oxygen OS Open Beta 5 for the OnePlus 7T and OnePlus 7T Pro
  1. hosseinito
    Cupcake Jun 12, 2020
    hosseinito , Jun 12, 2020 :
    I don't know if it's possible or not, but is it possible to make vibrations more stronger via software update?!
    I miss all notifications...
    #81
  2. Tausif.Shaikh786
    Eclair Jun 12, 2020
    #82
  3. #83
  4. ASCHENTE_V
    Jelly Bean Jun 12, 2020
    #84
  5. #85
    andrequeiroz likes this.
  6. Shridharsg
    #86
  7. Q1572037092872
    Gingerbread Jun 12, 2020
    #87
    domestoboto likes this.
  8. VB1
    VB1 , via OnePlus 7T , Jun 12, 2020 :
    If you aren't able to search & find the download link yourself then you defeat the purpose of a beta tester. Stay on the stable branch it will definitely help you & others.
    #88
    afogel, ahepas and Udit2508 like this.
  9. sri2127
    sri2127 , Jun 12, 2020 :
    hello all,
    still I didn't recieve new update and any idea on this to proceed further 🙂🙂🙂🙂
    #89
  10. shoghi07
    Froyo Jun 12, 2020
    shoghi07 , via OnePlus 7T , Jun 12, 2020 :
    Try restarting your phone and see the new OnePlus logo when the boots up.
    #90
  11. shoghi07
    Froyo Jun 12, 2020
    Wait for the OTA update or get it using the OnePlus updater app.
    #91
    sri2127 likes this.
  12. sri2127
    thanks bro I will wait because in oxygen updater its not showing latest update and it's showing only may month upfate
    #92
  13. sri2127
    #93
  14. tepetidis kostas
  15. Shridharsg
    Shridharsg , via OnePlus 7T , Jun 12, 2020 :
    Thanks for ur advice....
    #95
  16. Udit2508
    Froyo Jun 12, 2020
    #96
    bennyrose likes this.
  17. ssagheer
    Ice Cream Sandwich Jun 12, 2020
    ssagheer , Jun 12, 2020 :
    I agree the vibrations are weak but you can check if setting it to strong here makes it better.
    Settings > Sounds & vibration > Notification sound and vibration > Vibration intensity
    Also do same for Phone ringtone and vibration
    #97
    Dhanush akshay and pedritopl like this.
  18. hosseinito
    I've done that, but stiil can't understand notifications from telegram, etc.
    I hope that it'll be fixed... cuz vibration is important in vibrate mode...
    #98
  19. Fixxer
    Fixxer , via OnePlus 7T Pro , Jun 12, 2020 :
    This OB was really funny.
    First it stated that has one hand mode and it didn't and on the other hand, the change log says now we have a toggle for dark mode in the notification bar, but was already there on OB4!
    So, pretty much nothing new besides June security update.
    #99
  20. MMoo7
    Eclair Jun 12, 2020
