74
[SURVEY INSIDE] Oxygen OS Open Beta 7 for the OnePlus 7T and OnePlus 7T Pro
  1. afogel
    Froyo Sep 14, 2020
    afogel , via OnePlus 7T , Sep 14, 2020 :
    Yeah, I would not bet on that but would definitely appreciate it.
  2. BENJZ89
    Gingerbread Sep 14, 2020
    BENJZ89 , via OnePlus 7T , Sep 14, 2020 :
    yupp, there is no more solution until we wait for another coming to this ( new forum title )
    Udit2508 likes this.
  3. Udit2508
    Udit2508 , via OnePlus 7T , Sep 14, 2020 :
    BENJZ89
    there s no more beta might be , just closing to open Beta 1 ( A11) indeed . just wait for a long long time we're gonna snooring this time , or hibernating awhile
    Agreed. Maybe we'll get beta 1 directly. Lets hibernate till then. See yaaa
  4. J1599655241294 , via OnePlus 7T Pro Haze Blue , Sep 14, 2020 :
    i have 7t pro 8gb 256gb, i am facing heating issues while downloading or updating apps from playstore, after restart also, the upper area of screen is heated and metal rims on the upper side is heated. While playing pubg also it heats up badly it's irritating to touch. Im so worried and confused is my phone faulty? However I don't get any message that temperature too high or anything.
    Aniru_nya likes this.
  5. Fatih Aşkın
    Fatih Aşkın , via OnePlus 7T Pro , Sep 14, 2020 :
    try FHD+ Screen resolution setting. not QHD+ or Auto switch
    fatih.askn2 likes this.
  6. Aniru_nya
    Eclair Sep 14, 2020
    Aniru_nya , via OnePlus 7T , Sep 14, 2020 :
    I have the same issue with the 7T, I just press my phone on the AC till it cools down. No clue why it over heats. fyi, I get the messages.
  7. Q1570180865269
    Cupcake Sep 14, 2020
  8. S1552945482658 , via OnePlus Community App , Sep 14, 2020 :
    I have the One Plus 7T Pro McClearn, and tried to flash the latest Oxygen OS Beta. On the system update I have no settings tab in the top right had corner, or anywhere. It just says I ave the latest update from Aug 1, 2020. Any help would be appreciated .
    The great dane likes this.
  9. Udit2508
    I have the same issue with the 7T, I just press my phone on the AC till it cools down. No clue why it over heats. fyi, I get the messages.​
    Tbh you shouldn't do that. If the phone is hot, you force it to immediately cool down by pressing it on ac. That extreme temperature change is not good for the internal hardwares.
  10. Aniru_nya
    Eclair Sep 14, 2020
    Tbh you shouldn't do that. If the phone is hot, you force it to immediately cool down by pressing it on ac. That extreme temperature change is not good for the internal hardwares.[/QUOTE]Don't worry, it's not ice cold when I do that, I keep the temps neutral. But I wouldn't be doing that if the phone didn't heat up outta no where.
    I can sorta blame it on the extreme temperatures where I live, but I still don't think it's supposed to do that.
    BENJZ89 likes this.
  11. Udit2508
    Aniru_nya
    Okay. I suggest you visit OnePlus store once for the heating issue. As for me i have 7t too, sometimes it gets heated when i do very heavy gaming. Which is normal. or you could do a factory reset after backing up your data. or clear system cache. sometimes these things work.
  12. Aniru_nya
    Eclair Sep 14, 2020
    Okay. I suggest you visit OnePlus store once for the heating issue. As for me i have 7t too, sometimes it gets heated when i do very heavy gaming. Which is normal.[/QUOTE]
    Yeah, but gaming isn't the problem here, I rarely play nowadays. I just watch YouTube and listen to music. (And I don't use mobile data).
  13. Udit2508
    Yeah just shared my experience. My advice chat with OnePlus through their website and see what they say. Mostly this troubleshooting steps which i said can work. Or they'll ask you to visit store maybe. @Aniru_nya
  14. Aniru_nya
    Eclair Sep 14, 2020
    Yeah just shared my experience. My advice chat with OnePlus through their website and see what they say. Mostly this troubleshooting steps which i said can work. Or they'll ask you to visit store maybe.[/QUOTE]
    Yeah, they don't have a store where I live, and it's not like I mind, it's just a little bit annoying that I can't grab it without my fingers burning.
    Ill do a little bit of research before I take any action. Thanks for your advice!
  15. tryfe
    Froyo Sep 14, 2020
    tryfe , via OnePlus 7T , Sep 14, 2020 :
    That device is not part of the beta program.
  16. h1ghland3r , via OnePlus 7T Pro Haze Blue , Sep 15, 2020 :
    No, it was promised, then it was announced as it should be in a next beta build, but in the end they apologized a few days later. In short, we don't have this feature yet.
    Q1570180865269 and donaldvc like this.
  17. The great dane , via OnePlus 7T Pro McLaren Edition , Sep 15, 2020 :
    I've got same device as you and I'm on latest beta version (beta 7) runs quite decent without any major hickups.[e]1f44d[/e]
    ananyr and BENJZ89 like this.
  18. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 15, 2020 :
    T-mobile version?
  19. U1598581517772
    Cupcake Sep 15, 2020
