163
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. G_Vishesh_Saxena_qiww
    Froyo Jul 1, 2020
    G_Vishesh_Saxena_qiww , Jul 1, 2020 :
    VKJangir
    also facing brightness issue with auto brightness its not working While we play game its just stuck at the brightness level at which we exit the game we were playing
    while using other apps we have to again tap on auto brightness again​
    there is option in game space which you can turn off or on, usually auto brightness is turned off in gamespace, which if you want can turn on 1593620065150.jpg
  2. G_Vishesh_Saxena_qiww
    Froyo Jul 1, 2020
    if you are using that build in screen guard, try to remove it and then use ur fingerprint, sometime it may also cause problem
    see if ur ambient screen is on or off, if its off, turn it on for reliable lock
    if you are using your phn in dark surrounding, mayne that to can cause problem, because its optical fingerprint sensor not ultrasonic like samsung, or even when you reset ur fingerprint be in lighted area so more image of your prints may capture.
    or try to factory reset you phone to older stable version of oxygen os.
  3. L1571448340101
    Donut Jul 1, 2020
    L1571448340101 , via OnePlus 7T , Jul 1, 2020 :
    But ist not mentioned anywhere in the changelog of One Plus beta 5 about the network changes. Like when beta 9 was released for one plus 7 pro it was mentioned therr in the change log.
  4. B1592591224674
    Cupcake Jul 1, 2020
    B1592591224674 , Jul 1, 2020 :
    Just wait few days and you will get new update. i had same issue and solved by itself.
  5. bramgoodwin
    Gingerbread Jul 2, 2020
    bramgoodwin , via OnePlus 7T , Jul 2, 2020 :
    You are right. I have SF, TMOBILE OP7T, upgraded. Works great. Wish OP had separate forum for India or the have location so it is clear.
  6. Aashish345
    Donut Jul 2, 2020
  7. K1573628335229
    Cupcake Jul 2, 2020
    K1573628335229 , via OnePlus 7T , Jul 2, 2020 :
    Well this update has affected my phone's battery backup significantly. I am just getting a 8 hour backup when I use power saving mode all the time perhaps the worst update. OnePlus Please fix this ASAP.
  8. K1573628335229
    Cupcake Jul 2, 2020
    Well earlier my device used to give this backup on 10h SOT. Which is not awesome as it very less than my previous SOT. I always use power saving mode from 100 & always keep brightness on 20%.
  9. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 2, 2020 :
    There are many apps that can go nuts over time. Some apps can of no apperent reason start to drain battery like crazy.
    You may need to take a in depth look at both battery stat pages to see if there are anything that looks different. One app going nuts can be enough to cause a huge differance.
  10. K1573628335229
    Cupcake Jul 2, 2020
    Yes I know that some app may cause significant battery drain that's why I am using battery saver so that it curbs this kind of incident. I am writing this after observing the battery drainage for more than 2 weeks.
  11. K1573628335229
    Cupcake Jul 2, 2020
  12. harait
    Donut Jul 2, 2020
    harait , via OnePlus 7T , Jul 2, 2020 :
    Pay attention folks! I have to uninstall the facebook app because it causes to run 1 of 8 cores to run full blast. Install cpu-z to find out that you affected or not.
    Swejuggalo likes this.
  13. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 2, 2020 :
    Many apps can go nuts from time to time. Not just the Facebook app.
    It's always good to monitor what happens on the phone.
  14. harishke
    harishke , via OnePlus 7T , Jul 2, 2020 :
    Can any one confirm if recorded calls can be accessed from call history in 10.3.3 ? Im on beta 5 just for that,beta 5 missing one Plus bullet z integration in Dolby Atmos
  15. Deactivated User
    Jul 3, 2020
    Deactivated User , Jul 3, 2020 :
    While tapping on the settings page, the device is taking more than usual time to get there.
    Anyone experiencing the same ?
  16. T1593783961252
    Cupcake Jul 3, 2020
    T1593783961252 , Jul 3, 2020 :
    Hello Team,
    I'm really disappointed with new update where i can't edit my slow motion video which i love most.
  17. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 3, 2020 :
    Not the update fault. Disable automatic updates on Oneplus Gallery and uninstall updates of the app.
