164
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. N1592308430247
    Cupcake Jul 4, 2020
    N1592308430247 , Jul 4, 2020 :
    I tried, but same thing happens
  2. G_Vishesh_Saxena_qiww
    Froyo Jul 4, 2020
    G_Vishesh_Saxena_qiww , Jul 4, 2020 :
    its seems like there is something on ur flash thats directly reflecting flash light back to ur camera. not like nrml cases where the ligh bounce back from a object so u see the object
  3. N1592308430247
    Cupcake Jul 4, 2020
    have a close look on it, I used a camera protector, but that's not supposed to be any problem
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 4, 2020
  5. N1592308430247
    Cupcake Jul 4, 2020
    ok then, but it's not a big or software issues? right?
    then I'll remove the protector
  6. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 4, 2020 :
    You can always try a 3rd party camera like Open Camera or GCam first.
    An experiment could also be to cover the flash with black tejp or something flat covering only the led not filling the hole. If the glas indeed spreads light from the lens you can probably capture some light despite covering the lens
  7. N1592308430247
    Cupcake Jul 4, 2020
    ok brother, thanks a lot for your kind suggestions [e]2764[/e]️
  8. G_Vishesh_Saxena_qiww
    Froyo Jul 4, 2020
    if you are using a protector for camera lens maybe bcz the protector may reflect back some of the light back to camera which may create this kind of results, bcz glass doesn't not allow all light to pass through it, some of the light get reflect back. and if you are using plastic and thats covering that flash part then it will also create this kind of effects.
  9. Umesh420
    Froyo Jul 4, 2020
    Umesh420 , via OnePlus 7T , Jul 4, 2020 :
    How many days have passed since the new update came but the issue of navigation Gesture has not been fixed;swipe gesture is not happening as fast as before. If we come from another app on whatsapp, then quick gesture or swipe feels very laggy and it counts multiple touches at same time. And if we create a New Thread, you say search the Thread before creating a New one ;and now days your technical team does not respond quickly as before. Please fixed this bug asap.
  10. Prajot2518
    Eclair Jul 4, 2020
    Prajot2518 , via OnePlus 7T , Jul 4, 2020 :
    My Instagram , Google , whatsapp are lagging so much , I am fed up with that , my op 7t is lagging so much after the update , please can anyone suggest something to clear this . Please !
  11. G_Vishesh_Saxena_qiww
    Froyo Jul 4, 2020
    do a hard reset which will basically uninstall ur current update of oxygen os and roll back to that version of oxygen os which the phone was shipped with.
    D1571901826295 likes this.
  12. Prajot2518
    Eclair Jul 4, 2020
    Can I got to the previous version of this , and how can I go to it.
  13. G_Vishesh_Saxena_qiww
    Froyo Jul 4, 2020
    D1571901826295
    Can I got to the previous version of this , and how can I go to it.​
    1st thing most of people get confused with hard reset and factory reset
    hard reset is not factory reset,
    if u do factory reset it will wipe ur data and make ur phn brand new but with current version of os u have installed before ( that updated one)
    if u do hard reset it will roll back ur os to default version while also wiping ur data.
    and i guess yes you can install the version u like, via through downloads on official website or through 3rd party app like oxygen os updater (i really don't know the exact name) but u have to do this manually.
  14. Rajesh Shiva
    Gingerbread Jul 6, 2020
    Rajesh Shiva , via OnePlus 7T , Jul 6, 2020 :
    What can we expect in 10.3.4?
    Features that are available in beta such as
    1.Switch data to secondary sim during calls
    2. Wifi plus mobile data while downloading
    3. Icon changes for Volte, Data speed, Battery
  15. Ankit_2012
    Froyo Jul 6, 2020
    G1576171738004 and manoj.sv like this.
  16. E.D.T.H
    Eclair Jul 6, 2020
  17. Alike007
    Cupcake Jul 6, 2020
  18. airmotovlogs
    Honeycomb Jul 6, 2020
    airmotovlogs , via OnePlus 7T , Jul 6, 2020 :
    Alike007
    I see frezzing when i close apps. There is just wallpaper, then the icon of apps will appear!! Help!!​
    Free up your memory space if its filled up..next.If a simple Reboot doesnt help, then Backup & Reset should. Last option would be taking to the Service center...dont waste time in asking Oneplus Tech zsupport through this App here. They just don't bother to respond.
  19. karanRK
    Cupcake Jul 6, 2020
  20. Lonewolfnag
    Vishwas_dee likes this.
