164
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. Adarsh792000
    Froyo Aug 5, 2020
  2. amitexe786
    Gingerbread Aug 5, 2020
  3. cvganesh
    Cupcake Aug 5, 2020
    cvganesh , Aug 5, 2020 :
    Just now got 10.3.4 update for my OnePlus 7T it's really surprising that got the update so fast.
  4. cvganesh
    Cupcake Aug 5, 2020
    Oneplus official software upgrade page itself is showing 10.3.3.
  5. Andriy2412
    Eclair Aug 5, 2020
    Andriy2412 , via OnePlus 7T , Aug 5, 2020 :
    now everyone will start writing that they have received update. People, do you even read previous posts? Everyone already understood that the update came out
  6. VB1
    VB1 , Aug 5, 2020 :
    MarianCanea likes this.
  7. colaboy
    Honeycomb Aug 5, 2020
    colaboy , Aug 5, 2020 :
    you left out those whom haven't receive. same old thing, when when when. every time without fail.
  8. Sam197
    Jelly Bean Aug 5, 2020
    Sam197 , via OnePlus 7T , Aug 5, 2020 :
    Ok guys,from what I understand,this thread is only for OP7T,and it has nothing to do with new update10.0.4 which is belong to OP7 and 7 pro.
    I'm not saying you guys shouldn't talk about the new update but I think there is another thread for 7 and 7 pro.
    Enjoy the new update and good luck
    Stay safe
    Thanks
  9. V1576860545568
    Cupcake Aug 5, 2020
    V1576860545568 , Aug 5, 2020 :
    anyone tell me abot the heating issue that was in previous update is that solve in the new update or not please tell me
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 5, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 5, 2020 :
    I don't really know what happened on your device and when it was heated... But I often see a few people complaining about heat and battery drain on every single device on every single update thread.
    There are threads on this topic.
    7t
    https://forums.oneplus.com/threads/unified-battery-and-heating-feedback-thread-oneplus-7t.1110411/
    7t Pro
    https://forums.oneplus.com/threads/...ating-feedback-thread-oneplus-7t-pro.1124229/
    Checking the behavior on battery drain can be a good start. Sometimes the answer lies there. Missbehaving apps both drain a lot and cause heat.
  11. TumulNigam
    Froyo Aug 5, 2020
  12. TumulNigam
    Froyo Aug 5, 2020
  13. Q1592512406725
    Cupcake Aug 5, 2020
  14. Swejuggalo
    International/Global and EU version. BA just abides by some EU regulations. Also then we have the different hardware versions too that offers slightly different network bands
  15. Q1592512406725
    Cupcake Aug 5, 2020
    Q1592512406725 , Aug 5, 2020 :
    Which version should I install if I have the HD1900 model and live in the EU?
  16. Q1592512406725
    Cupcake Aug 5, 2020
  17. Swejuggalo
    If you don't have a problem with International just keep it. You get access to Equalizer for example. Does not exist in EU build.
  18. Swejuggalo
    A bit hard to say. The amount of no signal or unknown signal together with poor signal does not exactly call for a great battery time.
    And I have used Netflix too little to have a really good idea of how much it drains. Android system might be a bit high. If you very recently updated it it can be normal with higher drain until it settles down again.
    If you leave it on the charger for some extra time, over the night for example, it should be certain that it finishes a background optimization.
    It's also possible to manually run that process via adb shell.
    cmd package bg-dexopt-job
    It says Success when done. Keep it connected until then.
    Personally, the only time I'd buy a gray imported Chinese phone would be if I intended to use it as extra test device for DPs or closed betas or play around with Lineage OS and stuff. Then I'd have my main device bought for the intended region.
    I don't know if all the bands your carrier uses exists on the Chinese version.
    There is also a new update you can try now.
  19. Sundar786
    Froyo Aug 6, 2020
    Sundar786 , Aug 6, 2020 :
    New update 10.3.4 have received & Updated my OP7T. But I don't feel any new things
