148
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. Q1590166112050
    Cupcake Jun 2, 2020
  2. teopanta1
    Froyo Jun 2, 2020
  3. kubavat09
    Froyo Jun 2, 2020
    kubavat09 , via OnePlus 7T , Jun 2, 2020 :
    you have one more option to go to beta.
    1. download official rollback/downgrade zip file.
    2. download OB4 upgrade zip file.
    3. put both in root of the internal storage
    4. first flash rollback/downgrade zip via local upgrade.
    5. after flash, setup your oneplus as usual..
    6. after setup, flash the OB4 upgrade zip file via local upgrade.
    7. Now, you are on open beta.
    rollback/downgrade link:. https://androidfilehost.com/?fid=4349826312261744908
    OB4 upgrade you already have..
    Note: YOUR DATA WILL BE DELETED. SO MAKE A BACKUP FIRST.
  4. bprrkl
    Gingerbread Jun 2, 2020
    bprrkl , via OnePlus 7T , Jun 2, 2020 :
    yes it's safe and bro it's told about many times in the thread
  5. chiraggohil
    chiraggohil , via OnePlus 7T , Jun 2, 2020 :
    i want official updated.
    i don't want to be root. yar
  6. kubavat09
    Froyo Jun 2, 2020
    Indian
  7. kubavat09
    Froyo Jun 2, 2020
    chiraggohil
    i don't want to be root. yar​
    everything is official.
    the rollback back zip is given by oneplus officially.
    the OB4 is also given by oneplus officially.
    by doing the step mentioned , you wont be get rooted.
    you will just move from stable to beta..
    satish ungarala likes this.
  8. chiraggohil
    i don't want to download from 3rd party sites. which is unofficial.
    D1586020209881 likes this.
  9. kubavat09
    Froyo Jun 2, 2020
    its just a mirror of the official link of the oneplus. the zip file is on the oneplus server only..
    rest is youe choice.
    take care.
  10. sahil sonii
    Froyo Jun 2, 2020
    sahil sonii , via OnePlus 7 , Jun 2, 2020 :
    yeah they are using same camera sensor in 3 devices with some minor changes but 960fps could have come in one plus 7 as well.
    ananyr likes this.
  11. ASCHENTE_V
    Jelly Bean Jun 2, 2020
    ASCHENTE_V , Jun 2, 2020 :
    Oxygen Updater? If no, then wait.
  12. soansoram
    Eclair Jun 2, 2020
    soansoram , via OnePlus 7T , Jun 2, 2020 :
    This new update is not good after updated i found lots of bug lag likes Haptic feedback is not working while gaming theme customisation shade on Toggle pannel
  13. VB1
    Froyo Jun 2, 2020
    VB1 , Jun 2, 2020 :
    What type of theme?
  14. Manojshelte
    Donut Jun 2, 2020
    Q1590166112050 likes this.
  15. Q1590166112050
    Cupcake Jun 2, 2020
  16. MEET36
    Eclair Jun 2, 2020
    MEET36 , Jun 2, 2020 :
    I can't wait. i want to update my wireless z in to Dolby Atmos to batter sounds quality on my Op7t
    anyone updated then tell me the review of sounds quality of Wireless Z . with Dolby Atmos . batter or not .🥺
  17. ASCHENTE_V
  18. Q1590166112050
    Cupcake Jun 2, 2020
  19. dan197
    Cupcake Jun 2, 2020
    dan197 , via OnePlus 7T , Jun 2, 2020 :
    if you don't want to take people's advice then stay with the firmware you are using.
    kubavat09 likes this.
