164
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. Sgcool260294
    Froyo May 28, 2020
  2. Gaurav2904
    Froyo May 28, 2020
  3. Sgcool260294
    Froyo May 28, 2020
    Sgcool260294 , via OnePlus 7T , May 28, 2020 :
    india... haven't received any official system update yet... waiting for it...u also wait for it....m not sure if updating through oxygen updater is good
    flash47, A1574328179574 and Abhipupun like this.
  4. Gaurav2904
    Froyo May 28, 2020
    Gaurav2904 , via OnePlus 7T Pro , May 28, 2020 :
    cool. Make sense. Thank u mate.
  5. Blaks_524
    Cupcake May 28, 2020
    Deactivated User likes this.
  6. ananyr
    Honeycomb May 28, 2020
    ananyr , via OnePlus 7T , May 28, 2020 :
    same here [e]1f601[/e][e]1f601[/e][e]1f601[/e][e]1f601[/e][e]1f601[/e]
  7. Abhishek Srichandan , via OnePlus 7T , May 28, 2020 :
    720p 960fps video is limited to 10sec thats why
    J1577769579265 and Justin_JJaY like this.
  8. F1574958832622
    F1574958832622 , May 28, 2020 :
    Is the security problems being solved???
    I am facing serious issue with finger print unlock system
    guys if you want to know how I came accross this issue is that ....you disable the face unlock ...and then lock uh phone...once if you move uh finger upon the fingerprint scanner here and there 4-5 times and suddenly you swipe up your finger and your phone unlocks...this was done by one whose fingerprint was not saved in my phone ..my phone is oneplus7T
    R1573259624862 likes this.
  9. KarthikVPrabhu
  10. Sgcool260294
    Froyo May 28, 2020
  11. saroshtalha
    Gingerbread May 28, 2020
    VIKAS_RAIZADA likes this.
  12. Deathwish217
    Froyo May 28, 2020
    Deathwish217 , via OnePlus 7T , May 28, 2020 :
    Naveen Sd
    surya11496
    Is there new clock faces added in stable update ?
    no clock styles
    no android 10 status bar style
    no AOD
    no live caption feature
    message app update which not mentioned now it's sorting message like otp , promotion like that
    bullet wireless z pairing blazing fast, Experiencing DolbyAtmos
    960 fps recording is only 10 seconds
    battery back is normal
    and satisfaction is we update to latest security patch​
    aod isn't going to be ready till next month I think they said and then it will go into beta, probably won't see it till Android 11 comes out
  13. TeKnOGoD
    Eclair May 28, 2020
  14. Rahul_chanumolu
    Eclair May 28, 2020
    Rahul_chanumolu , May 28, 2020 :
    this new update has many bugs..i have done the update using Oxygen updater on my 7t...it has severe battery drain issues like 80 to76 in 5 min...and the notification panel sometimes turn back like previous greyish and sometimes turns into present black... please look into this OnePlus...and the 960fps.the vedio becomes blurry .... please fix this. problems...and some times i see aa pinkish shade from right side of my screen..
    Sushnata and vattyrockstar like this.
  15. roncoryfl
    roncoryfl , May 28, 2020 :
    long pressing on the battery saver shortcut is not launching into the normal battery settings, but to battery saver settings
  16. p51d007
    KitKat May 28, 2020
  17. MusaCariman
  18. ALNNN
    ALNNN , May 28, 2020 :
    It detects if your lenses are dirty, like the google camera app.
    M1569553578532 likes this.
  19. R1589356069553
    R1589356069553 , May 28, 2020 :
    I just received my unlocked 7T from OnePlus last week, and it is still on Oxygen OS 10.0.3. This is my first OnePlus phone, and I love it. The battery life is terrific (for now), but I'm hesitant to upgrade the OS, since I read about many people experiencing bad battery life after they upgraded the OS. I'd love to hear more about the battery performance after the 10.0.11 update, and any advice would be appreciated. Thank you!
    Olaobas likes this.
