164
[SURVEY INSIDE] OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. kwikOP7T
    Eclair May 29, 2020
    kwikOP7T , via OnePlus 7T , May 29, 2020 :
    I agree. I manually update from the oxygen updater as well.
    Here's what I observe:
    - The bottom bar appears sometimes even though it was disabled already
    - Messaging app, doesn't recognize which SIM card was recently used, it will always follow the default SIM for message from the settings
    - SIM Toolkit app shortcut is not present but you can manually access via the Settings
  2. ananyr
    Honeycomb May 29, 2020
    ananyr , via OnePlus 7T , May 29, 2020 :
    don't update
  3. chiraggohil
    Gingerbread May 29, 2020
  4. babijoee
    Cupcake May 29, 2020
  5. chiraggohil
  6. chiraggohil
  7. NiyasAhamed
  8. SahilCave75
    SahilCave75 , May 29, 2020 :
    Bro Delayed Due To Covid19!
  9. ananyr
    update problem ... i need OnePlus official
    i was on beta 4 so i update to last stable via oxygen updater application ... after wile the phone restart by him self more 2 time ... i tried to go to beta 4 .. but I can't ... so plz if u give my an way to install the official one ... thank you
  10. iamrohitparmar
    Froyo May 29, 2020
    iamrohitparmar , via OnePlus 7T , May 29, 2020 :
    I found a bug in this 10.3.3 indian version. Whenever i switch to dark mode from light theme the quik settings panel switched to grey not amoled black but rhe notification part is amoled black after restarting it switches to amoled black. this issue was present on betas but not on stable version but it is now in stable version.
    PrakharSaxena08 and Jake matt like this.
  11. rangeshvishal1999 , via OnePlus 7T , May 29, 2020 :
    use feedback tool bro, This is user forum
  12. Jake matt
    Eclair May 29, 2020
    Jake matt , via OnePlus 7T , May 29, 2020 :
    same problem here bro.
  13. akshay_honda
    Eclair May 29, 2020
    akshay_honda , via OnePlus 7T , May 29, 2020 :
    Good update. I think I can sense a slight improvement in battery performance/life.
    I was looking forward to a refreshed look with new status bar VoLTE icons and things. Hope that gets delivered in updates to come.
    The phone heated up just after the update. Did a hard cache clear and restarted. Charged the battery full and it's back to normal.
    R1589356069553 likes this.
  14. zer0mins
    Eclair May 29, 2020
    zer0mins , May 29, 2020 :
    I'm also looking forward for VOLTE, but still didn't support yet.
  15. Jake matt
    Eclair May 29, 2020
    _infected_technical_ likes this.
  16. H1589498205202 likes this.
  17. saikiran666
    Eclair May 29, 2020
