209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Rmz_._
    Eclair Jun 8, 2020
    Rmz_._ , Jun 8, 2020 :
    Adi_2019
    is your subject human or any object? i just tested it with an object and portrait mode is blurring background only, while subject is in focus. try moving away from your subject or tap on subject to focus on it.​
    tried on human (not working). on any other object it works.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 8, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 8, 2020 :
    Have you followed the recommendations suggested by the camera? You should see something similar to this.
    The example of the wall that close behind may also be harder for the camera.
    I've seen more people complain. It's possible that some change or bug exist. Since I don't have that model I can't replicate and verifiy.
  3. O1546708058016
    Cupcake Jun 8, 2020
    O1546708058016 , Jun 8, 2020 :
    are you using the 7 or 7 pro?
  4. O1546708058016
    Cupcake Jun 8, 2020
    I think the problem is for 7 not the 7 pro model
  5. MohitOneplus7
    Cupcake Jun 8, 2020
  6. Swejuggalo
    If you ask me. If you really want to deep dive into what drains on you phone you can use tools like BetterBatteryStats. You get a lot of stats that may help in knowing what caused your drain. Sometimes some apps simply missbehaves and need to be reset (wipe app cache or app data). Sometimes you may need to make sure it does not poll location constantly or any other thing if not really necessary (do all your social media apps really need location if you never ever use a function that needs it?). Every permission and/or smart feature is a possible battery draining component. Sometimes we need to figure out if an app is the best thing over the web version of the same thing or not (webpage shortcut instead). Some apps is simply pure hell in regards to battery and too high resource usage.
  7. O1546708058016
    Cupcake Jun 8, 2020
    I think the issue remains on the 7 only not the 7 pro. As I'm using the 7 pro and I don't find any issues yet.
  8. Swejuggalo
    I used to root myself. But lately most things I need can be done via adb and very few bonuses from root. Well... Different kernels and a few mods here and there would be nice... BUT as a beta nerd and wanting to report and replicate stuff on as a clean and unmodified system as possible... It creates a conflict of interest. I can't have it both ways without 2 phones. As tempting as it seems... I already want 2 phones so I can replicate both beta and stable specific issues easilly side by side... And use Lineage OS and possible closed beta... I would need a second job if I gave in for all my pleasures 😋
    Georgeoneplus7pro likes this.
  9. iamcamzzz
    Eclair Jun 8, 2020
  10. X1554211828531
    Gingerbread Jun 8, 2020
    X1554211828531 , via OnePlus 7 , Jun 8, 2020 :
    Yes first u need to roll back to pie then ota update come that way u can get update this process will erase ur data
    but if u wait some more day ob15 will come
  11. Arafat_israk
    Eclair Jun 8, 2020
    Arafat_israk , via OnePlus 7 Pro , Jun 8, 2020 :
    o don't got it some time thay say 10.3.3 is global and sometimes 10.0.6 is global.
    -_- day by day OnePlus becoming the none prime phone.
    every update thay adding new bugs -_-
    CHARAN05 likes this.
  12. r4zorR
    Cupcake Jun 8, 2020
  13. r4zorR
    Cupcake Jun 8, 2020
  14. Yosef..83
  15. Mr. Smith
    Eclair Jun 8, 2020
    Mr. Smith , Jun 8, 2020 :
    The launcher app settings must be reset. This will fix the problem, but the home page data and settings will be lost!
    Settings > Apps > Oneplus Launcher > Clear data & clear cache
  16. Anishsha
    Donut Jun 8, 2020
    Anishsha , via OnePlus 7 , Jun 8, 2020 :
    There is issue in tap to wake screen & lift to wake isn't working after leaving phone idle for sometime. Many users have these issue & i am having too..
  17. Anishsha
    Donut Jun 8, 2020
    clear data of launcher, will that solve the issue?
  18. Adi_2019
    Ice Cream Sandwich Jun 8, 2020
    Adi_2019 , via OnePlus 7 , Jun 8, 2020 :
    Sometimes such issues develop after an update. Reset your device. Lift to wake and double tap to unlock are working fine in my device.
  19. Vbj_OP_7
    Vbj_OP_7 , via OnePlus 7 , Jun 8, 2020 :
    I'm facing issues with portrait mode photos. It's not focusing on subject even after tapping on subject while taking a photo. How to fix this...?
