209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Adi_2019
    Ice Cream Sandwich Jun 8, 2020
    Adi_2019 , via OnePlus 7 , Jun 8, 2020 :
    I was also checking this with different objects in different scenes. The camera continues to struggles to lock focus on subject in portrait mode. This issue is only present in portrait mode of rear camera.
  2. Anishsha
    Donut Jun 8, 2020
    Anishsha , via OnePlus 7 , Jun 8, 2020 :
    ya i have been jus clearing cache of phone through recovery after every update but haven't done reset from the day i got my device. I have jus cleared the data & cache of launcher, lets c hope it fixs the issue..
  3. arjun1608
    Froyo Jun 8, 2020
  4. James 007
    Gingerbread Jun 8, 2020
    James 007 , via OnePlus 7 , Jun 8, 2020 :
    yes Bro there is a problem with double tap to wake ect specialy in dark environment (at night) sensor's and OOS are in deep sleep/pocket mode and it's nothing what can be done until next great update some people try to clean cache it's not working some fake master's are saying it's all fine it works for me so the people ho experience OSS malufanction are been dropped to category "it's your fault" No It's just garbage Update worst one ever made by this Corporation
  5. James 007
    My Friend they are people here that will say"be greatful that camera work's ho need's 720p it's outdated" I don't need this I don't need that it works for me because they trying to sell that Great Image about this Corporation and are not listening to Clients/Customers what are the problems and expectations and not fixing bugs just carrying them over to next shambles update .
  6. ASCHENTE_V
    KitKat Jun 8, 2020
    ASCHENTE_V , Jun 8, 2020 :
    Is there a point, when your crappy talking ends?
    kmaier, Artemus and Daasty like this.
  7. James 007
  8. Soumya120s
    Cupcake Jun 8, 2020
    Soumya120s , via OnePlus 7 , Jun 8, 2020 :
    when it somes to OnePlus7 ?
    OnePlus 6/6t had new updates of 10.3.4 but my OnePlus7 has not received the 10.3.3 update . please solve the issue.
  9. James 007
    Bro use Oxygen Updater from Play Store or other Side Downloads otherwise you gonna wait up to 14 days or forever For Great Shambles Updates
  10. rithesh.jain
    Eclair Jun 8, 2020
    balaji7 likes this.
  11. Vbj_OP_7
    Vbj_OP_7 , via OnePlus 7 , Jun 8, 2020 :
    After this update, the portrait mode is not able to focus only on human subjects, there is no issue with any other objects...
    sutanshu likes this.
  12. Vbj_OP_7
    I tried cleaning the lens, resetting the camera application and also followed the correct depth control distance...though it is blurring the human subjects. Is it only with OnePlus 7 or also for 7 pro? coz both the devices got the same update at a time in same batch...
  13. Anishsha
    Donut Jun 8, 2020
    i cleared data & cache of launcher, its working fine now.. try it
  14. James 007
  15. Vbj_OP_7
    Adi_2019
    is your subject human or any object? i just tested it with an object and portrait mode is blurring background only, while subject is in focus. try moving away from your subject or tap on subject to focus on it.​
    I tried both a human and some objects as the subject. It's working fine with all other objects but not with human subject. While clicking the picture it is staying focused but after clicking the shot, during the view the focus is gone...check the attached photo....
  16. Mr. Smith
    Eclair Jun 8, 2020
    Mr. Smith , Jun 8, 2020 :
    Yes.
  17. Anishsha
    Donut Jun 8, 2020
  18. donPepitoGrillo
    donPepitoGrillo , Jun 8, 2020 :
    Hi,
    Can you share a list of modules/apps you use with root?
    What do you think about Xposed Framework?
  19. deani77
    deani77 , Jun 8, 2020 :
    On my part, I get better battery on this update. If you just update let it settle down for a few days before come to conclusions.
    kmaier likes this.
  20. arun1092
