209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 9, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 9, 2020 :
    Sometimes they more or less auto respond it seems [e]1f609[/e]
    Question is... Was it posted as an suggestion or a bug (correct post method)
    kmchmk likes this.
  2. Karan_01
    Eclair Jun 9, 2020
    Karan_01 , Jun 9, 2020 :
    Last full charge - 23 hrs ago
    Screen usage since last full charge - 7 hrs
    This is the battery life I am getting after updating my Oneplus 7 pro to 10.3.3 . Is this ok?
    Is anyone getting the same, more or less?
    Ambranesshwar likes this.
  3. kmaier
    Honeycomb Jun 9, 2020
    kmaier , via OnePlus 7 , Jun 9, 2020 :
    no bug here
  4. Swejuggalo
    Very hard to say. I could get everything from 6-10h depending on day, where I was and what I did.
    Unless being a heavy gamer or using some very resource heavy stuff I expect a phone to last the full day.
    Karan_01 likes this.
  5. O1546708058016
    Cupcake Jun 9, 2020
    O1546708058016 , Jun 9, 2020 :
    yes this is fine
  6. kmaier
    if you don't want to use oxygen updater app, which is fine by the way, then you will have to wait.
  7. sam311
    Ice Cream Sandwich Jun 9, 2020
    sam311 , via OnePlus 7 Pro , Jun 9, 2020 :
    OnePlus loosing the grip just by launching new phones and TV is not going to help a lot....
    Moreover if you see closely Oneplus is failing in OP8 series as well.....Many tech users are preferring someother phones than OP8 series......
    First of all Oneplus is not listening to the users and not even giving proper Updates to fix issues.....In no time it will loose the users trust ....
    PS. - Only thing from China is currently having a good market value..... That is Oneplus..... Kindly don't be so bad at the end it will also get out of the market
    sujitnair30, SAGGY19, JohnTex and 2 others like this.
  8. UnicornZ
    UnicornZ , via OnePlus 7 Pro , Jun 9, 2020 :
    I don't understand. They are launching phone every six months and this has been the trend since 2016.
    Their line up is so clean compared to other companies. So what's the problem?
  9. sam311
    I am talking about the Update
    Jlsantiago89 likes this.
  10. VanleabK
    Froyo Jun 9, 2020
    VanleabK , via OnePlus 7 , Jun 9, 2020 :
    i can see many OnePlus team members here are trying so hard to depends it while actual users are complaining about bugs and so on ... lolz
    JohnTex likes this.
  11. UnicornZ
    sam311
    I am talking about the Update​
    Updates are pushed every two months as per their SLA. Also i was answering to your initial comment on product lineup.
  12. sam311
    Tell me something new....I am no noob....I am saying what about the Fix.... Regarding double tap, settings going blank....
    Moreover they are not giving the feature Update which came to beta three months backs.......
    Are you a moderator or Oneplus official ?
  13. UnicornZ
    Just take a chill pill. I am neither. I don't have to be a moderator or official to post in this forum. What is wrong with you folks. You didn't read my post clearly. I wasn't arguing for the issues that you are facing. Was saying the product line up is nothing new and its been there for 4 years. If you have anything to deny it, proceed or move on.
  14. sam311
    I asked you because even if would be a Official I would said to refer it to head team for improvements
  15. Vinny_jammula
    Eclair Jun 9, 2020
    Vinny_jammula , Jun 9, 2020 :
    same issue broo.... its making object or person blur instead of background
  16. Adi_2019
    Adi_2019 , via OnePlus 7 , Jun 9, 2020 :
    Yes I am also getting similar battery backup. It's normal. Neither very good nor bad. So, don't worry. I tried to check if dark mode saves any battery, but no noticable improvement with that too.
  17. sidthefreak
    Froyo Jun 9, 2020
    sidthefreak , Jun 9, 2020 :
    I have also started to experience increased battery drain using 10.3.3 on my OnePlus 7 Pro.
    The previous version was smoother and easier on the battery.
  18. Raghava2706
    Gingerbread Jun 9, 2020
  19. James 007
    James 007 , via OnePlus 7 , Jun 9, 2020 :
    Bro fan boy's will pint point that you are Wrong and OneMinus it's marvelous providing the best experience every no longer True series 7-8 are collapsing Corporation it's providing worst updates since series 3 because All they want it's Money
  20. O1546708058016
    Cupcake Jun 9, 2020
    Raghava2706 likes this.
