209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Lorenzo.Ragnar
    Donut Jun 10, 2020
  2. vipinmoza
    Eclair Jun 10, 2020
    vipinmoza , via OnePlus 7 , Jun 10, 2020 :
    Found a bug of sorts in 10.3.3 update for my OP7. So my phone was rapidly discharging after reaching 40% battery. The discharge was so rapid that phone switched off within 15 min. I reset the phone to factory default but it didn't resolve the problem. Screenshot below :
    Anyhow fearing hardware defect, I bought my device to service center and they diagnosed and downgraded the os version to 10.0.3 i think and battery drain issue was fixed. I set up my device, upgraded os version to 10.3.3 and I am well getting normal battery life without rapid discharge.
    Any idea what was causing the issue? A bad update perhaps or something
    Ashish900 and Venkatesh_thota like this.
  3. georgesunnyt
    Froyo Jun 10, 2020
    georgesunnyt , via OnePlus 7 Pro , Jun 10, 2020 :
    Did this update break gaming mode not being able to disable auto brightness for anyone?
    I downgraded to pie and upgraded to 10.3.2 and this issue wasn't present. Then I updated to 10.3.3 again out of curiosity and issue was present again. My friend with a op7 pro has the same issue.
    I've raised a bug in OnePlus community app.
    So if anyone relies a lot on gaming mode to turn off auto brightness like me, maybe skip this update.
    I just hope One Plus is more careful with quality control for these updates in the future
  4. Venkatesh_thota
    Froyo Jun 10, 2020
  5. Swejuggalo
    Community Bug Hunter Jun 10, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 10, 2020 :
    Well known issue. Mentioned many times already.
  6. Adi_2019
    Gingerbread Jun 10, 2020
    Adi_2019 , via OnePlus 7 , Jun 10, 2020 :
    so far everything is working fine except portrait mode of rear camera
    Venkatesh_thota likes this.
  7. Sanjeev16895
    Cupcake Jun 10, 2020
    Sanjeev16895 , via OnePlus 7 , Jun 10, 2020 :
    i updated to 10.3.3 and i think it will take some time to stablise...initially crashing too much but as i rested it for some time getting better
    And also i think this update will create little bit of heating issue...may cross 80°C of core processors
  8. Venkatesh_thota
    Froyo Jun 10, 2020
  9. Lorenzo.Ragnar
    Donut Jun 10, 2020
    Swejuggalo likes this.
  10. Adi_2019
    Camera struggle to lock focus on the subject. It produces blurry subject in the image.
  11. Lorenzo.Ragnar
    Donut Jun 10, 2020
  12. AnantDags
  13. midhmax@2021
    midhmax@2021 , via OnePlus 7 , Jun 10, 2020 :
    I got the update yesterday night and I didn't find any issue in tap to wake or pick up to wake feature. I couldn't find any bugs or issues so far
    chidi9901 likes this.
  14. Swejuggalo
  15. Swejuggalo
    The ones that got it says it does not happen instantly.You need to leave the phone alone for about 30 minutes or more. Then try to unlock
    sudheervenkata likes this.
  16. Adi_2019
    Could it be the desired behaviour of this update. A lot of complaints were made by people regarding battery backup since last update. Maybe after 30 or 60 minutes of no activity, the device goes into hibernation, where all sensors or background functions are suspended to minimise the power consumption.
  17. @raveendran
  18. K1565436027334
    K1565436027334 , Jun 10, 2020 :
    I got live captions in the Pro version. The regular OnePlus 7 didn't get the Live captions feature after the update.
    Is this intentional?
  19. Swejuggalo
    Only happens on 7 not 7 Pro though. And parts of a pocket mlde has been found.The pocket mode seems to use selifie camera as a helping sensor. Not possible on 7 Pro. With the fix possible for rooted users you actually get a pocket mode setting thst you can turn off.
  20. gaursayyam
    Froyo Jun 10, 2020
    gaursayyam , Jun 10, 2020 :
    Got the update yesterday.
    Have to say that the battery life is awesome with this update!
    After a long time, great job OnePlus!
    dosten likes this.
