209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. POE65
    Gingerbread Jun 11, 2020
    POE65 , via OnePlus 7 , Jun 11, 2020 :
    You can try backup data and factory reset....
  2. Mykel_Bahaa
    Cupcake Jun 11, 2020
    Mykel_Bahaa , Jun 11, 2020 :
    I got blurry Emojis in Facebook Messenger after the update, tried to clear cache and reinstall the APP.. Nothing changes....
    Any solutions please??
  3. B1586869007072
  4. Hardik_Piyeja
    Eclair Jun 11, 2020
  5. akks
    KitKat Jun 11, 2020
    akks , Jun 11, 2020 :
    Backup is taken to restore after you hard reset:cool::D
    Georgeoneplus7pro likes this.
  6. Hardik_Piyeja
    Eclair Jun 11, 2020
    Hardik_Piyeja , Jun 11, 2020 :
    why should i do that, they have to push another update for all the bugs
  7. Aniketh7
    Eclair Jun 11, 2020
    Aniketh7 , via OnePlus 7 , Jun 11, 2020 :
    but That hint has absolutely ruined double tap to wake, gestures and notifications.
  8. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 11, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 11, 2020 :
    Yepp. But there has been enough proof and posts about it so a fix should come. Problem is when.
    Aniketh7 likes this.
  9. Aniketh7
    Eclair Jun 11, 2020
    After going through this thread, it is clear that the incomplete Pocket mode on the 10.3.3 is the reason why features like Double tap to wake, gestures, and notifications lighting up the screen isn't working.
    one can test the same by covering the upper half of the phone ie the front camera with your hand and see none of the features work.
    is there a way to report this to the Dev's?
  10. Swejuggalo
    Feedback tool
  11. Aniketh7
    Eclair Jun 11, 2020
  12. Mirza_Azmatullah
  13. N_Zha
  14. dbajramo
    dbajramo , Jun 11, 2020 :
    I just updated to 10.0.6.GM21BA and am facing a bug. When I open an app that uses GPS (Location services) all my networking drops - WiFi and Cellular (4G). Then it needs around 5-6 seconds to come back again.
    Anyone facing the same issue? Any solution for this problem?
  15. B1586869007072
    B1586869007072 , Jun 11, 2020 :
    yes am also facing the issue
  16. laikexpert
    Honeycomb Jun 11, 2020
    laikexpert , Jun 11, 2020 :
    I have on my phone
    Oxygen OS 10.0.6.GM21BA
    Phone model GM1913
    Everything works normally
    Solution:
    -Clear the cache
    -Install the full version 10.0.6.GM21BA
  17. Ravi Rajan
    Donut Jun 11, 2020
  18. B1586869007072
    very much disappointed with the updates received since last 1 year,, sometimes battery gets drained faster, or operation gets slow, phone gets heated . it seems some sort to R&D is happening with our Phones in the name of updates.
  19. Kalyanam_zalke
    Ice Cream Sandwich Jun 11, 2020
    Kalyanam_zalke , via OnePlus 7 Mirror Gray , Jun 11, 2020 :
    i also noticed that when half of the upper screen is covered with hand then any messages and other notification comes but only sound Heard from the device and when its not covered then the screen on shows the notification.
    either its a good option for battery consumption like when the phone is in our pocket then then screen can saves little battery from the notification.
  20. Aniketh7
    Eclair Jun 11, 2020
    apparently it's only half the feature, the toggle for it is missing.
    the issue is you won't get notifications or gestures in low light too, so the toggle is necessary so that people can switch it off
    Kalyanam_zalke likes this.
