208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. KishoreVelijala
    Cupcake Jun 14, 2020
    sanjai10 likes this.
  2. kmaier
    Honeycomb Jun 14, 2020
  3. Milan_11
  4. T1592145085578
    T1592145085578 , Jun 14, 2020 :
    Hey
    since the new update I've got an annoying black bar below my keyboard. Anybody know how to do something about it?
    AnantDags likes this.
  5. UnicornZ
  6. UnicornZ
  7. Milan_11
  8. Q1592146504942
  9. Swejuggalo
    Lollipop Jun 14, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 14, 2020 :
    If they see the issue as critical they normally do. Guess we see
  10. RainGater
    Gingerbread Jun 14, 2020
    RainGater , Jun 14, 2020 :
    I highly doubt that they will send a hotfix. I reported the ambient display issue via feedback tool in OB 12/13. Now, we are at OB 15 and so far, it's a big Zilch.
    OP devs don't even see it as as issue or they are incompetent to fix it. I really wonder how their QAs test the existing functionality or only focus on new features?!? No integration/system tests I guess!
    Solution is simple, if you are rooted but many users are afraid to do it.
    Meanwhile, keep waiting forever as the OP devs are busy adding new lock screen clock designs. LMAO ;)
  11. Swejuggalo
    When you reported before did they ever say devs was looking at it? That is the info I have now atleast. Better than nothing I guess
  12. Vbj_OP_7
    Vbj_OP_7 , via OnePlus 7 , Jun 14, 2020 :
    Swejuggalo
    yes true....may be the issues we are facing are not reflecting on their testing model phones(same as in this thread, some people have zero issues)....so how can they fix the issue if it's not there for them....even if they try to fix it, they don't notice any difference before and after....
  13. RainGater
    When we are reporting bugs, it should go to them by default. Or, at least to the QA team. There was a generic message that someone was looking into it.
    It's crazy to add a half baked pocket mode which breaks other useful features... That's where you do the integration and a system test and if all the existing/new features work, you send it to production. In this case, they don't even give you a toggle to turn pocket mode on/off and it's hidden nicely.
    anupamabhay likes this.
  14. T1592145085578
    how annoying.
    thanks for the quick answer
  15. Vbj_OP_7
    what is the bottom right corner thing in that photo..what is it and how to enable?
  16. T1592145085578
    it enables the menu to change the keyboard
  17. sarahmic
    sarahmic , Jun 14, 2020 :
    What does one gain by rooting the phone - OP7 Pro ??
    What is the procedure please?
  18. meushgram
    Donut Jun 14, 2020
  19. Artemus.
    Nougat Jun 14, 2020
    DMaarten likes this.
  20. meushgram
    Donut Jun 14, 2020
    meushgram , Jun 14, 2020 :
    Artemus.
    Seeeeeearch... this has been reported countless times. Surely you can live without this feature.​
    Not really. The main purpose of the phone is camera ( in my case) and failing to take good pictures in a one day trip is clearly not acceptable hence creating a thread (clearly doing what i can instead of commenting carelessly)
    Y1562431593032 and unshuman like this.
