209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Astrogt
    Cupcake Jun 17, 2020
    Astrogt , Jun 17, 2020 :
    I downloaded this update yesterday and since then all my calls cut suddenly. it is usually after 1:25 to 2 minutes that all calls suddenly cut off, is anyone else experiencing the same problem ? Any help would be much appreciated it @OnePlus
    P1565936042723 likes this.
  2. Prasenjeet.Sinha
    Froyo Jun 17, 2020
    Prasenjeet.Sinha , via OnePlus 7 , Jun 17, 2020 :
    GCam link please....
  3. Sahil_lihas
    Honeycomb Jun 17, 2020
  4. Sahil_lihas
    Shiva_Rohith likes this.
  5. T1518500705859
    Eclair Jun 17, 2020
  6. Sahil_lihas
  7. himanshusaxena0001
    Gingerbread Jun 17, 2020
  8. himanshusaxena0001
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 17, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 17, 2020 :
    Regional and language settings. Make sure Device Personalization Services is updated. Wipe data on the app if needed. Use English UK or US as main language. Activate in settings. Should be enough. But still it does not seem to work for all.
  10. Swejuggalo
    sam_088 likes this.
  11. donPepitoGrillo
    Ice Cream Sandwich Jun 17, 2020
    donPepitoGrillo , Jun 17, 2020 :
    can anyone tell me if this guy is a bot?? because I always see their same kind of complaints without explaining what's wrong or giving more details. Looking at his other posts seems it's true :tearsofjoy:
  12. Swejuggalo
    Some seems to think it's all that is needed. Posting everywhere just improves the time of when the fix arrives [e]1f609[/e]
  13. akks
    KitKat Jun 17, 2020
    akks , Jun 17, 2020 :
    Ha ha... Exactly, I had the same thoughts
    Artemus. and donPepitoGrillo like this.
  14. sujitnair30
    Donut Jun 17, 2020
    sujitnair30 , Jun 17, 2020 :
    Wipe data of which app bro?
  15. Swejuggalo
  16. Georgeoneplus7pro
    Jelly Bean Jun 18, 2020
    Georgeoneplus7pro , Jun 18, 2020 :
    If it's not working as it should, the man will have to buy another phone with automatic brightness, for example Samsung and it works perfectly. Is that what you mean?
    balaji7 likes this.
  17. Artemus.
    Community Hero 2020 Jun 18, 2020
    Artemus. , Jun 18, 2020 :
    How did you get that inference from my post? All I said is, if it doesn't work why not just forego it and change the brightness manually? It's not that big of deal.
  18. P1565936042723
    Cupcake Jun 18, 2020
    P1565936042723 , Jun 18, 2020 :
    Speaker is not working after 10.3.3 update... While working in oneplus bullets wireless z.. Plz fix this isssue
  19. P1565936042723
    Yes.. I m also facing this problem
  20. Georgeoneplus7pro
    Only OnePlus 7 has the problem you mentioned.
    sam_088 likes this.
