209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 18, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 18, 2020 :
    Remove auto update in play store on that app (same broken version I got as beta user). Uninstall. Download this one. Install it and log back in.
    https://www.apkmirror.com/apk/onepl...mmunity-3-3-6-1-200512115615-c5a6406-release/
  2. Raghava2706
    Honeycomb Jun 18, 2020
    Swejuggalo likes this.
  3. sameerwadhwani
    Cupcake Jun 18, 2020
    sameerwadhwani , Jun 18, 2020 :
    Just after the update to 10.3.3, I am getting ambient screen issue, wherein the fingerprint scanner/clock does not light up, when I raise the phone or I single tap/double tap to wake (all these gestures/feature ls are enabled). Anyone else facing this issue? Found any solution?
    P1565936042723, rafab21 and sam_088 like this.
  4. Jav P
    Jav P , via OnePlus 7 , Jun 18, 2020 :
    That bug appeared with yesterday's update. Check mark instead of Return key and all the reply writes in one scrolling line. They fixed the automatic capitalization after period, though hehe
    Raghava2706 likes this.
  5. sameerwadhwani
    Yea, facing same issue. Did not find a solution. Tech help of oneplus suggested clearing cache and storage for oneplus system services under 'app settings'. But after a while it still reverts to unresponsive double tap/single tap/raise phone to wake screen.
    sam_088 likes this.
  6. sameerwadhwani
    +1
    This is the most troubled I have been in 6 years of using different generations of oneplus. Quite an annoying bug
    sam_088 likes this.
  7. sameerwadhwani
    Yes, I am facing all these issues. The slowness between switching doesn't bother me as much, but double tap to wake is a huge irk. Oneplus suggests wiping out cache, but that doesn't help
    sam_088 likes this.
  8. Raghava2706
    Raghava2706 , via OnePlus 7 Pro , Jun 18, 2020 :
    Please submit as bug and wait for next update [e]1f60a[/e].
  9. akks
    KitKat Jun 18, 2020
    akks , Jun 18, 2020 :
    last time 6 series received first open beta release after a month of beta release for 7 series. So expect 1-2 months delay after 8 series open beta release..
    Shalin235 likes this.
  10. G1569568295224
    Donut Jun 18, 2020
  11. F_Roi_Goldstein_TwwP , via OnePlus 7 Pro , Jun 18, 2020 :
    W1565160908126
    battery is draining. over night 40% is discharged with out any usage.
    worst rollout with out testing by OnePlus team. fix battery issue soon​
    Same happen to me .since last update last week i had battery issues..... Today i restarted the phone (just simple turn off and turn on).. i updated chrome app (the system showed that chrome is consuning most of the battery) and today, after the restart, the battery work fine, no draining, and it seems it fix the problem.
  12. Sachin.powani
    Sachin.powani , Jun 18, 2020 :
    Camera quality is too grainy.
    Updated the oxygen 10.3.3 and snapchat app.
    Snapchat camera is too grainy.
    Please help.
    sam_088 likes this.
  13. Shiva_Rohith
  14. sam_088 and pmem like this.
  15. Artemus.
    Community Hero 2020 Jun 18, 2020
    Artemus. , Jun 18, 2020 :
    Not gonna happen.
  16. Georgeoneplus7pro
    Jelly Bean Jun 18, 2020
    Georgeoneplus7pro , Jun 18, 2020 :
    What you say is true for your 8Pro. For series 7 it's a bit late for hopes.
  17. Georgeoneplus7pro
  18. Georgeoneplus7pro
  19. Karan_01
    Eclair Jun 18, 2020
    Karan_01 , Jun 18, 2020 :
    My Oneplus 7 pro is taking atleast 2 hrs to charge ( 1-100). Earlier it used to take around 75-80 mins. Anyone facing this problem?
