209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Artemus.
    Community Hero 2020 Jun 18, 2020
    Artemus. , Jun 18, 2020 :
    Do NOT let it drop below 10% if you can handle it. The more it drops that low, the less charge cycles it'll have.
  2. Hansel_Mendonca
    Cupcake Jun 18, 2020
  3. H1592510256944
    H1592510256944 , Jun 18, 2020 :
    Salve, dopo l'ultimo aggiornamento per OnePlus 7, ho riscontrato dei problemi evidenti riguardante il "doppio tocco per riattivare". Cercate di risolvere al più presto... attendo notizie
  4. G_Nicholas_Watson_DMuT
    Eclair Jun 18, 2020
    G_Nicholas_Watson_DMuT , Jun 18, 2020 :
    [QUOTE = "H1592510256944, post: 21735889, member: 3064667"] Hi, after the last update for OnePlus 7, I found evident problems concerning the "double touch to reactivate". Try to solve as soon as possible ... I await news [/ QUOTE]
    If you read back through this thread you'll find that his seems to be a very common problem with the OnePlus 7 since the last update.
    I have a 7pro and luckily don't have this problem.
    I hope those who are experiencing this bug get a fix soon but how long this will take is anyone's guess.
  5. vijayjgupta
    Eclair Jun 19, 2020
  6. Artemus.
    Community Hero 2020 Jun 19, 2020
    Artemus. , Jun 19, 2020 :
    When is the last time you wiped the device?
  7. vijayjgupta
    Eclair Jun 19, 2020
  8. Artemus.
    It's not required per se but it can fix some issues like lag. It's also recommended to do so at least once a year to keep it up to snuff.
  9. vijayjgupta
    Eclair Jun 19, 2020
    vijayjgupta , via OnePlus 7 Pro , Jun 19, 2020 :
    right it's not required. one should go ahead with wipe option when phone was working fine and suddenly starts responding slow. my phone is 6 months old only. in my case performance got worst post update. It seems there is no meaning of having 12gb ram in phone.
    rafab21 likes this.
  10. Artemus.
    Why not try my suggestion? It doesn't hurt and only takes ~5 minutes of your time (after backing up your data).
  11. Harsha09
    Gingerbread Jun 19, 2020
  12. unnamed.brother
    Donut Jun 19, 2020
    unnamed.brother , Jun 19, 2020 :
    So besides the bugs affecting a lot of other users (double tap to wake not working, portrait mode blurring the subject etc.), I recently found that incoming calls won't ring... As in the call would come, but the phone will only vibrate and not ring out loud. It only seems to happen with regular phone calls as other calls coming through apps such as WhatsApp, Messenger, MS Teams seem to work fine. Tried wiping the cache and everything but haven't been able to fix it. Appreciate if somebody could suggest a workaround 🥺
    rafab21 likes this.
  13. Georgeoneplus7pro likes this.
  14. Deepak4616
    Cupcake Jun 19, 2020
  15. laikexpert
    Honeycomb Jun 19, 2020
  16. aseel_muhamed
  17. aseel_muhamed
    aseel_muhamed , Jun 19, 2020 :
    why I am not getting update and onplus7t got slomotion update and battery optimization but why there is no updation in oneplus7 and 7pro it's very much disappointed verymuch disappointed we are mosly buying this phone to get the latest updates and you guys are playing bad .all the OnePlus users are degrading this updation and it's very much disappointed
  18. laikexpert
    laikexpert , Jun 19, 2020 :
  19. MuhammadSifat
    MuhammadSifat , Jun 19, 2020 :
    I think phone goes to deep sleep, lift to wake feature is not working properly, have to press power button menully after sometime phone being locked.
    rafab21 and POE65 like this.
