209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 23, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 23, 2020 :
    Does it ask for a 6 digit pin and you used 4 pin/fingerprint before? What is your installed version of File Manager? Update to 2.6.x path if you are on 2.5.x. Should exist via play store
    Artemus. and Abhi4050 like this.
  2. Abhi4050
    Cupcake Jun 23, 2020
    Abhi4050 , Jun 23, 2020 :
    thanks buddy
    Raghava2706 likes this.
  3. Shalin05
    Honeycomb Jun 23, 2020
  4. Swejuggalo
  5. Georgeoneplus7pro
    Jelly Bean Jun 23, 2020
    Georgeoneplus7pro , Jun 23, 2020 :
    Hello! Please recommend me the best NTP application, for time and GPS synchronization (with root of course) :)
  6. akks
    KitKat Jun 23, 2020
    akks , Jun 23, 2020 :
    What issues exactly?
  7. Shalin05
    Shalin05 , via OnePlus 7 Pro , Jun 23, 2020 :
    Actually both VoWIFI & VoLTE are enabled even disabling VoLTE doesn't resolve the issue and the funny part is whether i am on call or even normal its like the network is going and coming.
  8. Shalin05
    Well the connection is too weak and its not even constant whioe speaking on phone the phone disconnects and then the network is not there wifi is enabled then also
  9. Swejuggalo
    Same thing even if disabling both VoLTE and VoWiFi? That would force it to use 3G or lower for the call though.
  10. Shalin05
    Haven't tried that yet but i think that won't allow us to call through network!!!
  11. Swejuggalo
  12. akks
    KitKat Jun 23, 2020
    Which networks do you use? Try shuffling the sim slots.
  13. ron_R
    Eclair Jun 23, 2020
  14. Shalin05
  15. Shalin05
  16. akks
    KitKat Jun 23, 2020
    Jio is 4G only network. Won't work in 3G mode.
    Try changing to sim slot 2. If still issues persisting contact jio service centre.
  17. Shalin05
    I deleted the current vpn and again installed new vpn settings now let me have a check for the same
  18. akks
    KitKat Jun 23, 2020
    Okay, vpn or private DNS can also be the culprits. Try disabling all and check once
  19. Shalin05
    Okay so by default it is this, what should i keep?
  20. akks
    KitKat Jun 23, 2020
