209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. prasadssp
    Cupcake Jun 27, 2020
  2. AshisRanjanSenapati
  3. Artemus.
    Community Hero 2020 Jun 27, 2020
    Artemus. , Jun 27, 2020 :
    The ultimate control test.
    Adi_2019 likes this.
  4. DMaarten
    Honeycomb Jun 27, 2020
    DMaarten , Jun 27, 2020 :
    Well since you ask so f*cking nicely 🙄
    Artemus. likes this.
  5. Satrajit Chakraborty
    Satrajit Chakraborty , via OnePlus 7 , Jun 27, 2020 :
    Z1570266934951
    when will be the new update for one plus 7 pro currently Iam having 10.3.3 GM12AA​
    Some still havn't received the update and you are becoming crazy for the next. Have some patience bro!!
  6. derindavis
    Donut Jun 28, 2020
    derindavis , via OnePlus 7 , Jun 28, 2020 :
    Serious buggs.. please fix asp.. 1,when we open some apps screen going to full black. 2, when open a whats app audio file cant play screen going to off. Some time black out screen coming middle of payment process..
    sam_088 and R1571671360999 like this.
  7. UnicornZ
    Ice Cream Sandwich Jun 28, 2020
    UnicornZ , via OnePlus 7 Pro , Jun 28, 2020 :
    Swejuggalo
    Charge speed is the result of "capable charge current" - "heat created by the charge" - "active battery drain" - "heat causes by the ambiant temperature" =actual speed
    It does not stay constant all the time.​
    I believed in that untill i took an experiment. On Pie, full charge took only 64 minutes, after the update to 10, it takes almost 90 minutes. No it's not charging brick's fault, no its not cable's fault and it has everything to do with current intake due to software limitation in Android 10. On Pie, current intake would be 5800mA till it reaches 50% then it would drop gradually and maintains around 1700mA when it charges from 90 to 100. But in android 10, intake drops to 3400mA after reaching 25% and decreases from there and to make things worse, it takes only 600mA to go from 90 to 100.
  8. KryptonKalEl
    Donut Jun 28, 2020
    KryptonKalEl , via OnePlus 7 Pro , Jun 28, 2020 :
    Please add the option to add AM/PM for the time in the upper left corner. I should'nt have to install a 3rd party app just to get a simple feature and yet you change things like decreasing the volume in this update due to user complaint about the low volume not being low enough smh. What a joke from OnePlus dev team.
  9. VishalSah22
    Honeycomb Jun 28, 2020
    VishalSah22 , via OnePlus 7 Mirror Gray , Jun 28, 2020 :
    I noticed something in this update maybe I am wrong but here it is: touch to show display is working fine when phone is at home but as soon as I leave the home for office or anything it stops working and everytime I've to use the power button to unlock. Is there any connection with location?
  10. TITTOSAMTHOMAS
    Donut Jun 28, 2020
  11. Adi_2019
    Adi_2019 , via OnePlus 7 , Jun 28, 2020 :
    While there is no significant drop in battery backup, the advantage of doing this was that the phone kept all the apps in memory. It did not clear any of them. So, all the apps were pretty fast to load from recent apps, something we get to see in iOS. Android has been kind of aggressive in clearing apps to get some extra juice from the battery.
  12. Artemus.
    Community Hero 2020 Jun 28, 2020
    Artemus. , Jun 28, 2020 :
    The optimization is right there. Without graphs, we can't do anything.
  13. Amith98
    Froyo Jun 28, 2020
  14. Artemus.
    You realize you're in the wrong thread, right? The 7T has its own updates.
    Shadow0929 likes this.
  15. Amith98
    Froyo Jun 28, 2020
  16. Amith98
    Froyo Jun 28, 2020
  17. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 28, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 28, 2020 :
    True. There are differances. First there is the hardware boundery of how the charging is allowed to act. Then we have the software bounderies.
    I can imagine that a few tweaks and changes on how it charges changes over time. For example the area full speed is allowed.
    However... Same software. Same charger and cable. Different time. Then my listed parameters are the only changes.
    When having huge differances on the same software most cases are due to hardware or user specific software issues (damaged cable, some or several app causing both huge drain and heat for example).
    Many disconnect at 80% to save batterylife. Many are scared to death to charge during the night due to destroying the battery. Many raise concern over temperature during charging... At the same time people rage over 20+ minutes longer charge time... Good or bad... But didn't the same person's just do various things to save the battery and was worried over battery temp?
    paritosh9199 and Artemus. like this.
  18. Anshifansu
    Eclair Jun 28, 2020
  19. POE65
    Gingerbread Jun 28, 2020
