208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. SandeshChinchapur
    Ice Cream Sandwich Jul 13, 2020
    SandeshChinchapur , via OnePlus 7 , Jul 13, 2020 :
    Whoever is facing these issue, uninstall the OnePlus launcher and reinstall it. I've done the same and so far so everythingz working fine like before.
  2. sam_088
    Donut Jul 13, 2020
    sam_088 , Jul 13, 2020 :
  3. sam311
    sam311 , via OnePlus 7 Pro , Jul 13, 2020 :
    I just downloaded OnePlus Diagnostic APKand saw that my battery health status is 88% can anyone tell it's good or bad ....
    If bad how to improve that...I have attached
    nageswarraojami likes this.
  4. Satrajit Chakraborty
    Gingerbread Jul 13, 2020
    Satrajit Chakraborty , via OnePlus 7 , Jul 13, 2020 :
    As you are using Oneplus 7 pro I think its okeish type, unless you get very bad battery backup. If you are getting decent battery life then you can stick to it or else you can replace your battery. Totally your choice.
  5. sam311
    Yes OP 7 PRO
    But what I can do .....OP Should introduce the Optimized charging and also increase battery life
  6. Satrajit Chakraborty
    To get that feature as of now you have to get the beta builds or you have to wait for a stable rollout.
  7. Amirt85
    Eclair Jul 14, 2020
    Amirt85 , via OnePlus 7 Pro , Jul 14, 2020 :
    My only take on the new gallery features is that they are more or less close to the Google photos app offering . But Google's app offers a superior experience. I would focus on unique features that are not exist anywhere else.
  8. Atanu Maji
    Honeycomb Jul 14, 2020
    Atanu Maji , via OnePlus 7 , Jul 14, 2020 :
    It's been 1 year 1 month and my OnePlus 7 is at 87%. Surprise that two months back it was at 93% and I have never installed a game in it. The problem I found since the beginning till now is phone heating issue. If I stretch the usage phone battery temperature reaches 42°C. Cameras, heavy multitasking heats up the easily and battery drain like flow of downstream.
    In winter or, under air conditioning surroundings when atmospheric or, room temperature is below 30°C my OnePlus 7 stays cool as well despite having rough usages. Quick battery drain and phone temperature goes up while using phone outdoor, mostly under sun.
    I have requested and complained to OnePlus but it seems like they can't fix it.
    Iamsuniljinde and sam_088 like this.
  9. sam311
    Ice Cream Sandwich Jul 14, 2020
    sam311 , via OnePlus 7 Pro , Jul 14, 2020 :
    I guess I did that too...Mine was 93 too two months ago but no idea how it came down to 88% ....not played any games but still
  10. Shiva_Rohith
    Gingerbread Jul 14, 2020
    Shiva_Rohith , via OnePlus 7 Mirror Blue , Jul 14, 2020 :
    Same here Mate..!! Mine was in 5 months it came down from 90 to 88% then I stopped playing games ..n it's been like 2 months now it's 86% ..and also I'm having heating issue too..all the way upto 44°C
  11. sam311
    Did you report it in the feedback system?
    I did but no reply from Oneplus no idea
  12. Shiva_Rohith
    I did along back..that I'm having a serious heating issues etc ..but nothing seems to work out..!! All I did is to wait..for them to solve..!! Even i did visit a service centre..and they're all try to convince like..no it's fine..!! It happens sometimes..try to reset.or.they tell may b it's a software issue..will do solve by installing fresh software.
  13. sam311
    Bro just tag someone so that they can see
  14. Shiva_Rohith
  15. Shiva_Rohith
  16. sam311
  17. Shiva_Rohith
    Swejuggalo likes this.
  18. sam311
  19. Atanu Maji
    Reporting to OnePlus doesn't help as the very next thing they would do ask you to visit service center. While searching regards to heating issue I have found in some threads some fellow members straightforward refuse to agree that their OnePlus can heat up. They would say there is some technical issues in motherboard but then I find no heating in cold weather.
    I tried to report and disappointed. I have seen phones like Redmi K20, Asus Zenfone, even Poco (my friends use and they game) don't overheat probably due to bigger copper vapour pipe and better background app optimization.
