208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. P1594769487178
    Cupcake Jul 15, 2020
    P1594769487178 , Jul 15, 2020 :
    Hi,
    Anyone here using OnePlus 7pro 5g EU version?
    Just wondering when does it get updates etc security patches as I'm on latest which is may 🙈
  2. JayKawale
  3. UnicornZ
    Honeycomb Jul 15, 2020
    JayKawale likes this.
  4. Gdsingh94
    Ice Cream Sandwich Jul 15, 2020
  5. x_jayreghe_x
    Gingerbread Jul 15, 2020
  6. sam311
  7. Sandip Khadka
    Eclair Jul 15, 2020
  8. Jav P
    Jav P , via OnePlus 7 , Jul 15, 2020 :
    Those Google Play updates usually update in the background with no interaction from the owner. The only difference in this occasion ( July patch) is that the phone needed to be restarted so it pushed that notification.
    Tedinetto likes this.
  9. Venkatesh_thota
    Froyo Jul 15, 2020
  10. baggz143
  11. Jaswanth11
    Froyo Jul 15, 2020
  12. Satrajit Chakraborty
    Satrajit Chakraborty , via OnePlus 7 , Jul 15, 2020 :
    I just checked it myself . I think its better not to rely on the stats shown by the app as I don't think it is showing the correct stats. My battery stats shows 83%, and charging says warp charge though I am using a regular 20W dash charger for my OP7. I doubt the stats it is showing and it's not an official app by oneplus, I just checked the forum doesn't exist for this.
    Maybe but I am not sure...
  13. Shiva_Rohith
    Gingerbread Jul 16, 2020
    Shiva_Rohith , via OnePlus 7 Mirror Blue , Jul 16, 2020 :
    Yes...I agree.. Even I noticed while charging it shows warp charge for OnePlus 7 ..
  14. sam311
    Ice Cream Sandwich Jul 16, 2020
    sam311 , via OnePlus 7 Pro , Jul 16, 2020 :
    Just wanted to ask something on the Oneplus 7 Pro..
    In future are we going to get the Oneplus 8 UI design of camera for OnePlus 7 Pro...
    Or anything new for camera
  15. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 16, 2020 :
    My guess is that some of the long existing beta feats and some 8 series features will come with Oxygen OS 11. That would be the most logical step. That could possible include the camera GUI and possible some software filters. But that is just speculation from my side.
  16. sam311
    OP11 BETA means for OP 7T series....
    But I am asking for OP7 series
  17. Artemus. likes this.
  18. sam311
    Okay then, I took that as OP Beta .....So you are many major will come in Android 11...But don't you think as per Google the Stable will come around September ( As per news what I have seen) ...After that Oneplus 8 will receive stabel after than OP7 series....
    IT'S A LONG WAY THEN FOR MAJOR FEATURES
  19. Artemus.
    Nougat Jul 16, 2020
    Artemus. , Jul 16, 2020 :
    Bug fixes will always be a higher priority to gimmicks. Don't like it? Get another device that gives you new things every month that will probably break.
    Gdsingh94 likes this.
  20. sam311
    I am just having a normal conversation then why you are saying like I am saying or demanding something....And moreover do read the comment you have written it's sounds little bit awkward ....I am not complaining I am just asking....Did you find it offending anywhere??
    Then why you are saying that Get a new device....
