209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Kkravi0786
    Donut Aug 5, 2020
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 5, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 5, 2020 :
    Some say they never had issues with it. And hopefully it's fixed in 10.3.4 for those that had. As always it's rolled out in stages and not to everybody at once. If you are in a hurry you could use a 3rd party app (Oxygen Updater. Just don't change any settings and flash wrong region by misstake. The staged rollout is meant to protect you from possible unforseen issues) to get it or maybe if any source have posted the links. I have not seen any links yet though.
  3. Kkravi0786
    Donut Aug 5, 2020
    Kkravi0786 , Aug 5, 2020 :
    is it safe to install update from oxygen updater?
  4. Swejuggalo
    Well it is a 3rd party tool... Just double checking that you don't change region or something by misstake. It does not really make it different than manually downloaded files from Oneplus homepage. Just that you get access earlier. The risk you take though it getting it early and might install something that Oneplus may halt due to an unforseen critical issue. For that reason it can be good to wait. All depends how much hurry you have to update. Changes are that you get it soon anyway without doing anything. But it can take approx 2 weeks too.
  5. tarun2798
    Froyo Aug 12, 2020
    SuppNyUs likes this.
  6. Artemus.
    Community Hero 2020 Aug 12, 2020
    tarun2798 likes this.
  7. SuppNyUs
    Honeycomb Aug 13, 2020
    SuppNyUs , via OnePlus 7 Pro , Aug 13, 2020 :
    My camera completely freezes when I'm trying to take a photo on Instagram. I have to retry 2 to 3 times to get it to work, and it takes two minutes, what a 🆂🅷[e]1f170[/e]🅼🅴 !
    sam_088 and tarun2798 like this.
  8. tarun2798
    Froyo Aug 13, 2020
    tarun2798 , via OnePlus 7 , Aug 13, 2020 :
    Even me facing the same issue..I thought problem with the app...
    sam_088 and SuppNyUs like this.
  9. tarun2798
    Froyo Aug 13, 2020
    Artemus. likes this.
  10. nageshyannapusal
    Cupcake Sep 18, 2020
  11. Artemus.
    Community Hero 2020 Sep 18, 2020
    Artemus. , Sep 18, 2020 :
    Which update are you talking about?
  12. surajit20
    Froyo Sep 20, 2020
    E1559060679822 likes this.
  13. Artemus.
    Community Hero 2020 Sep 20, 2020
    Artemus. , Sep 20, 2020 :
    December, maybe.
  14. ianshul9
    Donut Sep 30, 2020
    OnePlus_dude and antonio0698 like this.
  15. antonio0698
    Cupcake Sep 30, 2020
    Monoranjan12 likes this.
  16. SandeshChinchapur
    Jelly Bean Sep 30, 2020
    ianshul9 likes this.
  17. anupmehra
    Honeycomb Sep 30, 2020
  18. manideep1006
    Cupcake Oct 1, 2020
    manideep1006 , via OnePlus 7 , Oct 1, 2020 :
    No I didn't get that yet but there are many problems with previous update had those solved like camera issues and etc
    Did those issues fixed??
  19. manideep1006
    Cupcake Oct 1, 2020
