208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. vaibhavvc
    Gingerbread May 30, 2020
    vaibhavvc , via OnePlus 7 , May 30, 2020 :
    I have had this update for 48+ hours now and I can only say that the battery behaviour is significantly worse. with my usage, I used to get 7-7.5 hours of SOT in a single charge on OOS10.3.2 and now I don't get more than 5.5 hours at best. I thought it might take a few charge cycles to settle, so I observed it across 4 charges but the behaviour is the same. The battery performance is much worse than the last update. your mileage may vary.
    I have tried clearing cache and a factory reset to no avail.
  2. psylektro7
    Cupcake May 30, 2020
    Darsh93 and SandeshChinchapur like this.
  3. Sunil+
    Froyo May 30, 2020
    Sunil+ , May 30, 2020 :
    Yup, I too jumped to update locally on this one. downloaded the package from XDA website and updated from update settings.
  4. udayJR
    Froyo May 30, 2020
    udayJR , via OnePlus 7 , May 30, 2020 :
    I contacted the customer care and this is what they had to say. The update for all devices would be available after a month. Due to COVID 19, they haven't been able to fix everything completely. Hope this helps for all the queries regarding the update issue. Cheers, everyone.
  5. Artemus.
    Nougat May 30, 2020
    Artemus. , May 30, 2020 :
    As with every update, the battery must be calibrated which happens after the battery reaches 100%.
  6. Sunil+
    Froyo May 30, 2020
    Wrong interpretation?? Chat person said next month, can mean june as well.
  7. Swejuggalo
    Lollipop May 30, 2020
    Swejuggalo , via OnePlus 7 Pro , May 30, 2020 :
    I do hope he drank too much beer before replying though (or actually he meant next month, in other words in a few days) ... I assume you asked about 7 International firmware?
    SandeshChinchapur likes this.
  8. vaibhavvc
    it has reached 100 four times.
  9. udayJR
    Froyo May 30, 2020
    Both international and Indian versions. According to him, updates would be received by next month. I'm not sure. I asked him about the clock styles and revamped notification icons, he said the upper management hadn't told anything about that.
  10. Artemus.
    Nougat May 30, 2020
    And how long did you keep it on the charger after reaching 100%?
  11. vaibhavvc
    usually, I charge overnight and then use it the whole day. but on this update, I've had to charge overnight+ in the evening on both days. so it stays at 100 overnight, but in the evening, I keep it on 100 for 5-10 minute before taking it off
  12. Swejuggalo
    They are the same (just an extra India.img internal that applies only on India devices).
    So approx 2 days or more for the rest then.
  13. Artemus.
    Nougat May 30, 2020
    Why do you have to charge it in the evening as well? How low does it get before you put it on the charger?
  14. Swejuggalo
    No specific app or system component that seems to drain extra much?
  15. udayJR
    Froyo May 30, 2020
    I hope the next update brings the clock styles and the notification icons with better battery management.
  16. vaibhavvc
    nope. ive used the device exactly the same as previous update and the stats also show the same.
  17. vaibhavvc
    it gets to 15ish percent by evening ( on 10.3.2, it used to reach 15% by midnight)
  18. mayank_002_
  19. Mrinalchaudhary
  20. D1562685063067
