208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Rahul_Dubey9443
    Eclair Jun 1, 2020
  2. RishinP
    Eclair Jun 1, 2020
    RishinP , Jun 1, 2020 :
    nope still waiting patiently
  3. J.shah
    Cupcake Jun 1, 2020
    yogeshg24@gmail. likes this.
  4. Swejuggalo
    Lollipop Jun 1, 2020
    Swejuggalo , via OnePlus 7 Pro , Jun 1, 2020 :
    Up to 2 weeks can be perfectly normal after the announcement. It's a staged rollout
  5. CharanGarapati
    Froyo Jun 1, 2020
  6. Y1562500399805
    Cupcake Jun 1, 2020
    yogeshg24@gmail. and Shalin235 like this.
  7. Shalin05
    Gingerbread Jun 1, 2020
    Shalin05 , via OnePlus 7 Pro Nebula Blue , Jun 1, 2020 :
    Swejuggalo
    Up to 2 weeks can be perfectly normal after the announcement. It's a staged rollout​
    But generally the stage rollout is fast compared here actually no one is receiving is the point.....so many goof ups with updates in beta as well...[e]1f602[/e][e]1f602[/e][e]1f602[/e]
  8. Ignatius_loyola
    Eclair Jun 1, 2020
  9. kmaier
    Honeycomb Jun 1, 2020
    kmaier , via OnePlus 7 , Jun 1, 2020 :
    mine works ok
  10. X1567084170296 , via OnePlus 7 Pro , Jun 1, 2020 :
    hey, does the security patch have an influence on device speed ? i does the update and i should do a factory reset. after this the security patch was on 1 october. my phone was incredibly fast. after update to ultimate version (1 may) the phobe is slower. please someone answer me. [e]1f64f[/e]
  11. G_El_Hadj_Chitou_zagD
    Donut Jun 1, 2020
  12. sarahmic
    sarahmic , Jun 1, 2020 :
    I have no problems with Tap/Double Tap but can't find Live Caption.
    Where do i go looking for it please?
  13. Vyklouz
    Cupcake Jun 1, 2020
    Vyklouz , Jun 1, 2020 :
    Hello. Anyone got this? it's appears after last update. Thanks for reply
    SandeshChinchapur likes this.
  14. kmaier
    swipe down from top to quick tile settings, tap pen for edit, then down below you should see it. drag it up to top half and save.
    sarahmic likes this.
  15. Ambranesshwar , via OnePlus 7 Mirror Gray , Jun 1, 2020 :
    look for it in the highlighted area, if it's not there then you didn't receive it
  16. T1582879064692
    Cupcake Jun 1, 2020
  17. Swejuggalo
    Vyklouz likes this.
  18. Sajidur Rahman
    Eclair Jun 1, 2020
    Sajidur Rahman , Jun 1, 2020 :
    I have a major issues with my every earphones and earbuds(except wireless z). After updated to 10.3.3 ,Bass on the Left earpiece is much Lower than Right one. Also can't find the live caption feature.
    any body else have the same issue?
  19. vaibhavvc
    vaibhavvc , via OnePlus 7 , Jun 1, 2020 :
    Rolled back to OOS 10.0.3 and my screen on time is back to 6.5-7 hours (I'd discount the other 30 minutes I used to get before to battery degradation). 10.3.3 has a severe effect on my battery. might just be me. staying on 10.0.3 for the foreseeable future till I am sure OnePlus has a good update
  20. O1587630740306
    Cupcake Jun 1, 2020
    O1587630740306 , Jun 1, 2020 :
    your accent colour?
    Loki55 likes this.
