208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. ron_R
    Donut Jun 1, 2020
  2. Swejuggalo
    Lollipop Jun 1, 2020
    Swejuggalo , via OnePlus 7 Pro , Jun 1, 2020 :
    Security patches does normally not affect speed. Many different speed can affect speed. Installed apps, heat,momlery usage.
  3. Fernandomedina70
    Cupcake Jun 1, 2020
    Fernandomedina70 , Jun 1, 2020 :
    ¡¡¡Hola!!! Que pasa con la pantalla cuando se reinicia,se duerme y para el PIN hay que despertarla antes no era así,es normal?? Automáticamente reiniciabas y ponías el PIN. Con wipes no se soluciona!!
    Bobby_Rivera likes this.
  4. SandeshChinchapur
    Ice Cream Sandwich Jun 1, 2020
    iSheikHArif and Vyklouz like this.
  5. Vyklouz
    Cupcake Jun 1, 2020
    Vyklouz , Jun 1, 2020 :
    I have already send feedback. will see
  6. gilkman
    Cupcake Jun 1, 2020
  7. Swejuggalo
    An unlocked version? Most often the rollout seems slow in USA... Despite that the rest of the world seems to follow regular stages rollout
  8. X1567084170296 , via OnePlus 7 Pro , Jun 1, 2020 :
    i didn't understand
    LukaTk23 likes this.
  9. Swejuggalo
    Ah... Autocorrect 😋
    Security patches does normally not affect speed. Many different stuff can affect speed. Installed apps, heat, memory usage.
    Does it make more sense now? [e]1f609[/e]
  10. X1567084170296 , via OnePlus 7 Pro , Jun 1, 2020 :
    oh yes, thank you very much [e]1f44d[/e]
  11. Swejuggalo
    If you never charge during the night try that a few times. That will allow the device to do background optimizing
    X1567084170296 likes this.
  12. BuxtonLad
    Gingerbread Jun 1, 2020
    BuxtonLad , via OnePlus 7 Pro , Jun 1, 2020 :
    hi. how do you roll back? I'm on 10.0.6 and want to put beta 14 on. cheers
    vaibhavvc likes this.
  13. J1590147201601
    Cupcake Jun 1, 2020
  14. shikhan_sarkar
    shikhan_sarkar , Jun 1, 2020 :
    Yes, I have checked. I haven't got Live caption. Screenshot_20200601-192539.jpg Screenshot_20200601-192602.jpg
  15. Swejuggalo
  16. BuxtonLad
  17. Swejuggalo
    Unless they have made beta 14 able to flash over Pie you need either beta 5 or OTA your way up to 10.0.3 (or any earlier 10 stable) first before flashing.
    So one way would be to rollback. Do ONE OTA. Download and flash beta 14.
    Rollback wipes all data
  18. BuxtonLad
    thanks again buddy. I'm struggling to find beta 5 download. any ideas? cheers for your help
  19. Swejuggalo
    Some older beta update posts always mentioned beta 5 and provided links. Now they don't mention it. If that means we don't need it or that they just think most don't need it anymore because "everybody" is on 10 anyway is the question.
    Beta 11 post mentions beta 5 with links.
    https://forums.oneplus.com/threads/oxygenos-open-beta-11-for-the-oneplus-7-pro-and-7.1202558/
    BuxtonLad likes this.
  20. S1572152217694
    Cupcake Jun 1, 2020
    J1590147201601 likes this.
