208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Gdsingh94
    Ice Cream Sandwich Jun 2, 2020
    Gdsingh94 , via OnePlus 7 , Jun 2, 2020 :
    laikexpert
    Settings
    Buttons & gestures
    Navigation bar & gestures
    CHOOSE NAVIGATION BAR
    Examples:
    1.) Navigation gestures, (arrow bellow keyboard) is to turn off the keyboard.
    2.) Back, Home, recents, (arrow bellow keyboard) does not exist at all.
    View attachment 1328476 View attachment 1328477
    P.S.
    In addition, on my phone
    I use Gboard keyboard & Nova Launcher.​
    the back button becomes the down arrow in 3 button nav... look carefully....
  2. zihaf17
    Gingerbread Jun 2, 2020
  3. core25
    Cupcake Jun 2, 2020
    core25 , Jun 2, 2020 :
    battery doesn't seem too be better it's actually worst and phone is mildly warm and getting hot
    Rex0Rajput22 likes this.
  4. Sean Forde
    Eclair Jun 2, 2020
    Sean Forde , Jun 2, 2020 :
    Thanks for the update but the auto rotate button still does not show up if the bottom bar is hidden on the OnePlus 7 Pro. This has been the case since the "new" navigation gestures were introduced. Has anyone found a workaround for this(besides showing the bottom bar) or know of a fix being in the works?
    Luigiformentini likes this.
  5. Artemus.
    Nougat Jun 2, 2020
    Artemus. , Jun 2, 2020 :
    After an update, the phone will feel warmer and the battery will drain a bit quicker than before and is completely normal.
  6. RealSirMorokei , via OnePlus 7 Mirror Gray , Jun 2, 2020 :
    True and I didn't face any battery drain issues. First charge after the updates was not as good as before. The second full charge is exactly like before but stand by battery life has improved.
    Artemus. likes this.
  7. Artemus.
    Nougat Jun 2, 2020
    Congrats!
    Q1571005298566 likes this.
  8. maazkazi1991
  9. starboy1910
    Froyo Jun 2, 2020
    starboy1910 , via OnePlus 7 , Jun 2, 2020 :
    No freaking improvements over the battery after the current update. OB 14 is much better at saving battery (esp. stand-by battery drain) and any of the recent or previous updates whatsoever. What the hell OnePlus!! Why does the beta gets the best things since the inception of the beta build. Why OnePlus? why?
  10. Artemus.
    Nougat Jun 2, 2020
    Of course there's no battery improvements, the battery is just fine. You just need to learn how to manage it better.
  11. starboy1910
    Froyo Jun 2, 2020
    Then OnePlus had to mention it in their change logs that we had to manage it ourselves and not actually say 'Battery improvement'. If anything like that has been mentioned in the changelogs then it is ought to have that improvement or else what is the even point? See with the likes of you I can say that you don't know shit. So you better sit tight in one corner and wait of what this company has to provide it to you. Btw, yes there are ways that company can implement to improve the battery life more (freaking off the telemetry)
  12. Bobby_Rivera
    Bobby_Rivera , Jun 2, 2020 :
    It's weird, I was using the fixed navigation, but I tried the navigation gestures with the bottom bar being shown and now it is back to normal! Thanks Swejuggalo
    Sean Forde and Swejuggalo like this.
  13. saurabh125
    Eclair Jun 2, 2020
    saurabh125 , via OnePlus 7 , Jun 2, 2020 :
    does anyone have any idea about how these stage roll out happens? is it according to model number (I guess so) or manufacturing dates or any other criteria??
  14. Artemus.
    Nougat Jun 2, 2020
    The criteria: completely random. No pattern of who gets it. If you can't wait, there exists an app to bypass the OTA process called Oxygen Updater.
    saurabh125 likes this.
  15. Deactivated User likes this.
  16. wolf4477
    Froyo Jun 2, 2020
    wolf4477 , via OnePlus 7 , Jun 2, 2020 :
    yes, i observes that It happens un dark environments when proximity sensor doesnt detects nothing near, but there arent light
  17. Ambranesshwar , via OnePlus 7 Mirror Gray , Jun 2, 2020 :
    For me it happens when the phone is left idle for more than a minute. in that situation I have to use the power button to wake the phone
    Before 10.3.3, everything was fine.
    Deactivated User and starboy1910 like this.
  18. RehanTsy
    Donut Jun 2, 2020
    starboy1910 and Ravitejanayudu like this.
  19. VanleabK
    Froyo Jun 2, 2020
    starboy1910 likes this.
  20. RehanTsy likes this.
