208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Pavana__D
    Eclair Jun 3, 2020
  2. ASCHENTE_V
    Jelly Bean Jun 3, 2020
    ASCHENTE_V , Jun 3, 2020 :
    Staged rollout. Use oxygen updater or wait.
  3. ADMOrange
    Froyo Jun 3, 2020
    ADMOrange , via OnePlus 7 , Jun 3, 2020 :
    I kind of fixed the issue.. I flashed a full Oxygen OS 10.3.3 file, not the OTA which is around 250 plus MB. The RAM usage returned to normal.
    James 007 likes this.
  4. Sanchitmeena
    Froyo Jun 3, 2020
    Sanchitmeena , via OnePlus 7 , Jun 3, 2020 :
    exactly Ambient display, live captions. nothing is there.
    shikhan_sarkar likes this.
  5. VinodGOP7
    Froyo Jun 3, 2020
    VinodGOP7 , Jun 3, 2020 :
    Strange, but double tap, single tap and pick up your phone all have started to work again. I did not do any changes. The only thing I did was to walk a few meters. I am not sure if this mattered.
    thanks,
    Vinod
  6. G1510792206174
    Froyo Jun 3, 2020
    G1510792206174 , Jun 3, 2020 :
    [QUOTE = "ADMOrange, post: 21677313, membro: 2309848"] Eu meio que corrigi o problema .. Atualizei um arquivo completo do Oxygen OS 10.3.3, não o OTA, que tem cerca de 250 MB ou mais. O uso da RAM voltou ao normal. [/ QUOTE]
    were you having this problem too?
    ADMOrange likes this.
  7. G1510792206174
    Froyo Jun 3, 2020
    [QUOTE = "Harsha_PV, postagem: 21676859, membro: 2449413"] Após a atualização,
    Toque duas vezes para ativar e
    O seu telefone para mostrar não está funcionando corretamente.
    Gente, tenha cuidado para atualizar para 10.3.3 ou aguarde o próximo lançamento. [/ QUOTE]
    I have this same problem, it was terrible after the update
  8. Rajat jain16
    Donut Jun 3, 2020
    Rajat jain16 , Jun 3, 2020 :
    Nice update,
    did anyone notice ? there are some changes in the message app.
    some new things are added in it which makes your life more easier .
    one can easily delete the message from the notification itself.
    And the transactional part .
  9. Raveendran v
    Froyo Jun 3, 2020
    paritosh9199 likes this.
  10. G_TV95_MeLm
    Ice Cream Sandwich Jun 3, 2020
    G_TV95_MeLm , via OnePlus 7 Mirror Red , Jun 3, 2020 :
    Long pressing Battery tile in Notification Shade opened the Battery settings page before. Now it opens Battery Saver. It was helpful before as we could immediately see battery statistics. Now we have to go into the settings app and open Battery.
    Also, Tap-to-wake and Lift-to-wake gets disabled if phone has not been touched for a while? Bug? Was working perfectly before.
    Love the new Battery Saver icon though. And not having the persistent notification anymore.
    Battery Stats : 24hrs since last charge, 8hrs SOT. Satisfied with battery life.
    MoIcam and Shalin235 like this.
  11. Akshay011
    Cupcake Jun 3, 2020
    Akshay011 , Jun 3, 2020 :
    it's 1-1.5 meter from mobile
    what i do now?
    solve my issue
  12. AshishManjaly
    Cupcake Jun 3, 2020
  13. RealSirMorokei , via OnePlus 7 Mirror Gray , Jun 3, 2020 :
    G_TV95_MeLm
    Love the new Battery Saver icon though. And not having the persistent notification anymore.​
    Pull down the notification shade and press on the battery icon. That will bring you to the battery settings.
  14. G_TV95_MeLm
    Works, but still not good enough for one-handed use. Thanks for the advice though. Didn't know this.
  15. G1510792206174
    Froyo Jun 3, 2020
    ramsri05 likes this.
  16. I1566915091940
    Cupcake Jun 3, 2020
    I1566915091940 , via OnePlus 7 Pro , Jun 3, 2020 :
    Unfortunately, since the last update my phone (7pro) keeps freezing when I'm in the browser and from time to time when opening and or closing apps, only when I turn my screen off and on again it will unfreeze which is fine for once or twice, but gets annoying after a few times a day...
    Georgeoneplus7pro and Shalin235 like this.
  17. Konrad G.
    Cupcake Jun 3, 2020
    Konrad G. , Jun 3, 2020 :
    I have live caption option after 10.0.6 update on my OP 7 Pro
  18. shikhan_sarkar
    Gingerbread Jun 3, 2020
    shikhan_sarkar , Jun 3, 2020 :
    Could you please tell me how to do that? Because I am also facing some problem after updating my device to Oxygen OS 10.3.3.
  19. Vivaan19
    Froyo Jun 3, 2020
