208
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. DerNachbar
    Gingerbread Jun 3, 2020
    DerNachbar , via OnePlus 7 Pro , Jun 3, 2020 :
    known issues for a long time (I'm not the only one):
    - mobile data slow down ( to 3-6kb/s)and gets really crappy if you operate a 2nd SIM (in roaming). as soon you turn off the 2nd SIM card it gets back to normal. it doesn't matter if sim 1 or sim 2. problem exist on both slots as long there is a 2nd sim active. have it on 6T and on 7 pro. already reported. you can find people with same issues everywhere. cleaning cache, even a factory reset doesn't solve the problem.
    - camera is not good in picture mode but brilliant in video mode. you show us that it work for videos. just show as that you can fix the software for pictures as well.
    Y1562500399805 likes this.
  2. Sanchitmeena
    Froyo Jun 3, 2020
    Sanchitmeena , via OnePlus 7 , Jun 3, 2020 :
    So is there any solution ?
    Ambranesshwar likes this.
  3. rahulkshinde
    Eclair Jun 3, 2020
    rahulkshinde , via OnePlus 7 Pro , Jun 3, 2020 :
    The got the update yesterday, Live Captions are also for 7T series I think do it see it on my op7pro.
    not much difference in the battery life either for me.
  4. Georgeoneplus7pro
    Jelly Bean Jun 3, 2020
    Georgeoneplus7pro , Jun 3, 2020 :
    I'm not in a hurry. I'm waiting for the 8T series, maybe a model without a hole in the screen will come.
    BiancaFritz and Swejuggalo like this.
  5. A1576875725578
    Cupcake Jun 3, 2020
  6. O1587630740306
    Cupcake Jun 3, 2020
  7. Ambranesshwar , via OnePlus 7 Mirror Gray , Jun 3, 2020 :
    Sanchitmeena
    So is there any solution ?​
    I wiped the cache data twice with minimal to no difference with regards to the problems I faced
    all these are software related problems
    only time will tell whether there will be a fix for this
  8. shikhan_sarkar
    Shiva_Rohith likes this.
  9. Sanchitmeena
    Froyo Jun 3, 2020
    after wiping cache files, did it fix the problem?
  10. shikhan_sarkar
    shikhan_sarkar , Jun 3, 2020 :
    Thanks. Will this process erase all my data? Should I need to get backup before?
  11. Swejuggalo
    Lollipop Jun 3, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 3, 2020 :
    You may need to contact support more directly regarding this.
    https://www.oneplus.com and go to Support for regional support channels (chat, mail and phone)
  12. shikhan_sarkar
  13. Sanchitmeena
    Froyo Jun 3, 2020
    I will suggest you one thing. Go to settings- apps and notification- all apps - then on top right corner select app preferences.
    So please do this and respond if it improves the situation.
  14. Mohd_Sameer_
    Donut Jun 3, 2020
    Mohd_Sameer_ , Jun 3, 2020 :
    after updating to OxygenOS 10.3.3 I have encountered a problem with volume on OnePlus 7. Earlier 10 to 15 percent volume was used to be fine but now I need crank it upto 40 to 50 percent. OnePlus please fix this issue. It has degraded the user experience.
    Ashish900 likes this.
  15. Ambranesshwar , via OnePlus 7 Mirror Gray , Jun 3, 2020 :
    are you telling me to reset the app preferences under settings - apps & notifications and reset?
  16. Sanchitmeena
    Froyo Jun 3, 2020
    Yes, do only reset preferences. Nothing else.
  17. Sanchitmeena
    Froyo Jun 3, 2020
  18. shikhan_sarkar
    Is this program available in India? Can I trade my OP 7 too? If yes, then what's the procedure?
