209
[SURVEY INSIDE] OxygenOS 10.0.6 [EU & Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 3, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 3, 2020 :
    Yepp. Please report to Oneplus via the feedback tool.
    The more reports the better. Just mentioning it here may not give the desired effect. Just hope it shows how common this is so it's proven that it is not just pushed to the side as a "just a few" isolated issues.
  2. H@ppyj@ri
    Donut Jun 3, 2020
  3. akks
    KitKat Jun 3, 2020
    akks , Jun 3, 2020 :
    That's exactly OnePlus update schedule. It was published here way back
  4. TonyJo
    Cupcake Jun 3, 2020
    TonyJo , via OnePlus 7 , Jun 3, 2020 :
    I'm facing problems with double tap to wake. I don't know why but it seems related with the proximity sensors.
    I'll try to explain it better.
    I'm fully stock, no root no unlocked bootloader.
    I'm using a flip cover and when the phone it's closed inside the cover happen that if i try to double tap for waking it, it doesn't wake up until i click on the power button.
    it's a super strange behavior because.. there's like no way to power on the phone without unlocking it from the power button.
    I'm on 10.0.6 and this sorta of bug happens from about months so it's not related to last rom.
    i tried to reset the phone but the problem is still there.
    Is there any way to fix this?
    James 007 likes this.
  5. H@ppyj@ri
    Donut Jun 3, 2020
    H@ppyj@ri , via OnePlus 7 , Jun 3, 2020 :
    i updated my phone on 28th may ...in evening at 8.30 pm , from last few days i am facing phone hanging problem , working slow , touch problem (during typing ) , mic n speak er probelm , double tapping problem and battery dragging problem also ... continue ..and phone working too much slowly
    what cann i do ?[e]1f612[/e][e]1f614[/e]
  6. Nitin.Nk
    Cupcake Jun 3, 2020
    Nitin.Nk , Jun 3, 2020 :
    The lock screen changes it color for a while. I took screenshot but when I checked screenshot it seems there is no issues. I came across the same issue 3 times in a single day after getting the latest update
  7. Ronak3567
    Gingerbread Jun 3, 2020
    Sakib4 and RealSirMorokei like this.
  8. James 007
    James 007 , via OnePlus 7 , Jun 3, 2020 :
    yes problems with double tap to wake are still here you can unlock phone without power button by moving the phone to awake the screen so the phone Will show you actual time then double tap Will work I believe the problem at list in my case is when I don't use it overnight OSS/sensor are in deep sleep And that Couse malfunction of them it should be fixed long time ago as it's well known Problem but 1+ don't really Care about closing this Matter
  9. James 007
    clear cache first . this will not resolve double tap to wake problem I didn't I my case after night I need to move phone when screen is showing me actual time then double tap works (deep sleep of OSS/Sensor's I believe are the problem) but if you are willing to full reset phone this may help but you need to backup the phone And start from scratch 1+ has some sort of problems with last updates but that was expected when 8 series was announced
  10. Sumit1212
    Cupcake Jun 3, 2020
    RuchiThaker likes this.
  11. RealSirMorokei , via OnePlus 7 Mirror Gray , Jun 3, 2020 :
    Agree, sound is way too loud and doesn't sound good because of audio overdrive.
  12. Sanjeev16895 likes this.
  13. Sakib4 likes this.
  14. Artemus.
    Community Hero 2020 Jun 3, 2020
    Artemus. , Jun 3, 2020 :
    Because you fail to be patient.
    Georgeoneplus7pro likes this.
  15. RealSirMorokei , via OnePlus 7 Mirror Gray , Jun 3, 2020 :
    Btw. I really appreciate you for being here and helping the community. You put a lot of time in helping others and that is really great. Thank you!
  16. Artemus.
  17. G1510792206174
    Froyo Jun 3, 2020
    G1510792206174 , Jun 3, 2020 :
    [QUOTE = "dhaval071, post: 21679321, membro: 2177079"] Vejo um problema no meu OP7 após a atualização para 10.3.3.
    A tela ambiente não aparece ao tocar ou pegar. Efetuou as configurações novamente e reiniciou, mas o problema ainda está lá. [/ QUOTE]
    I have the same problem after updating 10.3.3
  18. Artemus.
    Just an FYI, your translator is breaking quotes. Maybe just translate the content itself and not the BBCode?
  19. ADP10
    Eclair Jun 3, 2020
    ADP10 , Jun 3, 2020 :
    The mode in the pocket that was included in the update is to blame, and therefore when there is not enough light, the phone thinks that it is in the pocket, you need to turn off this mode, but this requires root rights. Why did OnePlus even remove this mode from the settings and turn it on? Why is there no choice?
    Metronibux and G1510792206174 like this.
  20. ADP10
    Eclair Jun 3, 2020
    Who has root rights, you can turn off the mode in your pocket, then the tap will work perfectly, here is the way: / system / etc and find the feature_list file, add this code
    "featureName": "OP_FEATURE_ENABLE_POCKETMODE_SWITCH"
    and reboot, after setting - utilities and the mode item appears in your pocket.
    Only for OP7.
