38
[SURVEY INSIDE] OxygenOS 10.5.9 [IN], 10.5.8 [EU] and 10.5.10 [NA] for the OnePlus 8
  1. TommyHudd
    Froyo Jul 14, 2020
    TommyHudd , via OnePlus 8 , Jul 14, 2020 :
    Not showing what? you mean not showing 'warp' charge while we charge it?
  2. E1594214856655
    Cupcake Jul 14, 2020
    E1594214856655 , via OnePlus 8 , Jul 14, 2020 :
    yes it's not showing wrap !!. And the device charging very slow in 30 mins 29% it's charged
  3. TommyHudd
    Froyo Jul 14, 2020
    You definitely have a hardware problem then man. Mine warp charges no problem. Maybe your cable is broken or the adapter is faulty. if you have a friend who has a OnePlus warp charger I'd ask to use it, then you'd be able to determine if the problem is with the device itself or the charger
  4. abhishek_manyam
    Eclair Jul 14, 2020
  5. Q1590738468006
  6. rohith_mohan07
    Froyo Jul 14, 2020
  7. AbhijeetGandhi , via OnePlus 8 Pro , Jul 14, 2020 :
    I face the same issue. Also Netflix and prime does not work in fullscreen mode over punch hole
    Dilbagh2011 likes this.
  8. M1594631852342
  9. SwarnavaDe
    Froyo Jul 14, 2020
  10. rohith_mohan07
    Froyo Jul 14, 2020
  11. SwarnavaDe
    Froyo Jul 14, 2020
  12. rohith_mohan07
    Froyo Jul 14, 2020
    rohith_mohan07 , via OnePlus 8 , Jul 14, 2020 :
    I recently had a conversation with one of the oneplus bughunter, inferring about the selfie cam not supporting full screen aspect ratio after 10.5.9.IN21DA update. And the reason they give is that "The viewing angle will be so narrow if we provide full screen, so they permanently removed that feature and set it as 4:3 always".[e]1f633[/e][e]1f633[/e][e]1f633[/e][e]1f633[/e]
    The thing they could have done is to provide all the defailt aspect ratios( Full Screen, 4:3, 1:1). And those who need better viewing angle can choose the ratio of their interest.
    I got all the 3 settings with my Oneplus8 out of the box. And i ruined that feature by updating to software version 10.5.8.IN21DA ( IN11 Model) . Should have not done that update [e]1f616[/e][e]1f616[/e][e]1f616[/e]
  13. SwarnavaDe
    Froyo Jul 14, 2020
    SwarnavaDe , via OnePlus 8 , Jul 14, 2020 :
    Hey man, I've found a solution to the issue ane had it fixed. Here's how
    Reboot your phone a couple of times and then check your widevine certification. It should be now on L1.
    For Netflix, try uninstalling all the updates from playstore, disable it. And try reinstalling it again.
    This worked for me. [e]1f60a[/e]
  14. ESHWAR KHANNA
    Donut Jul 14, 2020
  15. ESHWAR KHANNA
    Donut Jul 14, 2020
    ESHWAR KHANNA , via OnePlus 8 , Jul 14, 2020 :
    you know what bro, you are the best, it is fixed for me as well [e]1f602[/e]
    SwarnavaDe likes this.
  16. SwarnavaDe
    Froyo Jul 14, 2020
    I'm glad it helped 🤗 I'm happy too
    ESHWAR KHANNA likes this.
  17. Nikhil Thor
  18. thetruthofOp8
    Eclair Jul 14, 2020
  19. RKO8726
    Donut Jul 14, 2020
  20. ankitmaity
    Gingerbread Jul 14, 2020
