38
[SURVEY INSIDE] OxygenOS 10.5.9 [IN], 10.5.8 [EU] and 10.5.10 [NA] for the OnePlus 8
  1. T4hir
    Cupcake Jul 15, 2020
    T4hir , Jul 15, 2020 :
    Still getting the mobile data issues with the update :'(
    just to clarify, this is when the handset is in sleep mode or screen off. Messages such as WhatsApp do not get delivered unless the phone is woken up and then a flurry of messages come through.
    please fix.
  2. Deactivated User
    Jul 15, 2020
  3. N1593679741757
    Froyo Jul 15, 2020
  4. PanosI
    PanosI , via OnePlus 8 , Jul 15, 2020 :
    I don't play games but apart from that phone is always on my hand and checking it constantly.
    I also noticed that I have increased temperature during the warp charge.
  5. V1577433239345
  6. Chérif Ketrandji , via OnePlus 8 Glacial Green , Jul 15, 2020 :
    Yeah I heard many people did. Didn't notice anything in that department on my side.
  7. D1586871376733
    D1586871376733 , via OnePlus 8 , Jul 15, 2020 :
    But my earphones have an angled projection so that it will fit in that particular ear only. :(
  8. ankitmaity
    Gingerbread Jul 15, 2020
    ankitmaity , via OnePlus 8 , Jul 15, 2020 :
    This seems like Android 10's battery Intelligent Control/Optimize mode, just set the mode to don't optimize and it should work fine.
  9. ankitmaity
  10. T4hir
    This isn't the issue as I also have a Oneplus 7 which works absolutely fine and both are set on "intelligent control" under battery.
    So definitely an underlying issue somewhere.
  11. ankitmaity
    That doesn't matter, Intelligent Control will behave differently in each phone depending on how you use it. I'm telling you because I experienced this with Instagram, it might be a different issue (also note that OP7 and OP8 use different OS versions) but no harm in trying.
  12. T4hir
    Took the advice and tried with no success. I'm open to suggestions.
  13. ankitmaity
    That's disappointing, I was getting a lot of battery drain and ended up having to get a replacement hopefully it works out for you!
  14. Sankew
    Donut Jul 16, 2020
    Shimon_Asulin likes this.
  15. rohith_mohan07
    Froyo Jul 16, 2020
  16. Azzlan786
    Eclair Jul 16, 2020
    Azzlan786 , via OnePlus 8 , Jul 16, 2020 :
    Okay, so, this build is solid. Everything is working fine and battery life has been great.
    The only problem I've encountered is overheating when charging the phone. Besides that, overall experience is great.
    DrAKSHAY177 likes this.
  17. N1593679741757
    Froyo Jul 16, 2020
  18. rohith_mohan07
    Froyo Jul 16, 2020
    rohith_mohan07 , via OnePlus 8 , Jul 16, 2020 :
    Which software version ???🤔🤔
