75
[SURVEY INSIDE] OxygenOS 11.2.7.7 for the OnePlus 9 and OnePlus 9 Pro
  1. Ajay33 , via OnePlus 9 Winter Mist , Jun 17, 2021 :
    I pay the price so i expect the phone to run cooler than other midrange smartphones atleast by a degree or 2.
    Im speaking here cuz i have compared it with other phones and i feel disappointed...And i said heat management was good in 11.2.6.6. Phone touches 40° if i start to use the phone for 5mins.
  2. Trebronix , via OnePlus 9 Arctic Sky , Jun 17, 2021 :
    That is literally impossible. As I've said in my earlier post if a CPU/battery runs at 40 degrees it's not noticeable since the heat dissipates in every direction and those few degrees become a fraction of that on the outside. What's heating the phone up on the outside is your hands from holding it. Glass is not a very good heat conductor. What you're saying is normal and it's not the phone's fault. It's no one's fault. It's the laws of physics.
    Ajay33 likes this.
  3. veda2810
    Honeycomb Jun 17, 2021
    veda2810 , via OnePlus 9 Pro , Jun 17, 2021 :
    I never quotes 26 degrees but I've observed multiple people blame social media apps but that's not correct as I've said before this isnt the 1st device we are using these are baasic apps which are installed in almost all phones
    Debopriyo2791 likes this.
  4. Debopriyo2791 , via OnePlus 9 Pro Pine Green , Jun 17, 2021 :
    I didn't face any heating issue with my device till 11.2.6.6.But after installing 11.2.7.7 i observed a little bit heating issue specially when using youtube for some time .I wiped the cache and it was gone after that.You can try that too..
    Abbas.B likes this.
  5. Debopriyo2791 , via OnePlus 9 Pro Pine Green , Jun 17, 2021 :
    I second you on this.Using social media apps can't be the only excuse for battery drain.Yes facebook, instagram these are battery draining apps ,i agree.But never was to this extent on other devices/other os we used.This might be an issue with optimization of oxygen os 11 for this device.And i am pretty sure even if we stop using them there won't be a drastic change in battery life..
    veda2810 likes this.
  6. veda2810
    There have been multiple issues with OOS 11
    cited out not only in community but across social media platforms not sure if anyone's listening
    Even 1 hour improvement in SOT in the 9 pro would make a world of a difference
    From a least 3.30 to 4 hrs to atleast 5 to 5.30 hrs vass minimum is required
    Whist most premium flagships provide 6 hours +
  7. Aaron2017
    Lollipop Jun 17, 2021
    Aaron2017 , Jun 17, 2021 :
    It's one thing to complain about updates, but to say that you're waiting for a month when it's in fact 10 days is basically lying to prove a point.
    Caomhin likes this.
  8. p373r66
    Froyo Jun 17, 2021
    p373r66 , Jun 17, 2021 :
    I dont think these people who wants to get in touch by peronal message with you and get a debug log is developers at OP, they are just middle man between forum users and the "real" developers that actually working with the software. They are just forwarding the information to the developers, so we never gonna get an answer no matter how much we ask these people.
  9. Huigiebaby
    Ice Cream Sandwich Jun 17, 2021
  10. choiwah
    Eclair Jun 17, 2021
  11. speeddevil44
    Donut Jun 17, 2021
    speeddevil44 , via OnePlus 9 Pro , Jun 17, 2021 :
    Κατέβασε το Oxygen updater. Είχα τον ίδιο πρόβλημα, αλλά όχι πια...
  12. zantenios87
    Eclair Jun 17, 2021
    zantenios87 , via OnePlus 9 Pro , Jun 17, 2021 :
    Εσύ το έχεις λάβει το τελευταίο; Εγώ όχι ακόμα και όταν βάζω και το oxygen updater πάλι δεν το δίνει μήπως δεν έχεις την ευρωπαϊκή έκδοση;
  13. mr_laemp
    Froyo Jun 17, 2021
    mr_laemp , via OnePlus 9 Pro , Jun 17, 2021 :
    Please use English so that anyone has a chance to read your message
    Boz33, zantenios87 and speeddevil44 like this.
  14. speeddevil44
    Donut Jun 17, 2021
    Not the 7.7 but the 6.6
    zantenios87 likes this.
  15. nosvasedis
    Gingerbread Jun 17, 2021
    Boz33 likes this.
  16. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 17, 2021
    Caomhin , via OnePlus 9 Pro , Jun 17, 2021 :
    Try the following.
    Open Gmail, Go to Settings, click on your account,
    Click on Inbox Notifications. Make sure Notify for every message is selected.
    And in Email Notifications, ensure All is selected.
    Click on Manage Notifications make sure Pop on Screen is enabled.
    If you have more than one account, ensure you do the same for them all.
    Check if this can help with Gmail Notifications.
    Aaron2017 and nosvasedis like this.
  17. nosvasedis
    nosvasedis , via OnePlus 9 Pro , Jun 17, 2021 :
    Tried them all so far... 😭
    paulswift36 and Caomhin like this.
  18. Caomhin
    The info I gave you fixed the Gmail notification issue I had.
    The following also works for some as well. There doesn't seem to be a perfect fix for this.
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions for all your Apps again.
    Check if this can help.
  19. nosvasedis
    Thanks, will try it out
    Caomhin likes this.
  20. Spyros_Kastanas
    Cupcake Jun 17, 2021
    Spyros_Kastanas , via OnePlus 9 Pro , Jun 17, 2021 :
    Can any Oneplus representative inform us if this update is delayed for EU due to issues noticed so far? There was never such delay to receive the update after announcing it in the official App. Are there any plans to be released to EU after all or you are working on improvements and fixes?
    Thanks!
    oTeMpLo, fidus62 and Karsten_G like this.
