75
[SURVEY INSIDE] OxygenOS 11.2.7.7 for the OnePlus 9 and OnePlus 9 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 7, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jul 7, 2021 :
    Depends on your activity, idle activity and so on... A SoC that can run at 80°C will obviously be a problem if being at that level too long time. If you also have a higher ambient temp your time frame before the heat also heats up the battery will be shorter.
    Your battery needs to be within 5 to 45°C... Obviously a problem since the SoC always produces some heat and spreads it in the phone body to cool down. High ambient temp requires optimal usage of resources to keep the heat generation as low as possible.
    Some that followed my guide found something and sometimes solved the problem. Sometimes by a so simply way as charging for longer times (see last user comment in my guide... All he did was to let the maintenance (dexopt) job finish by charging differently... ).
    Worst case it does not solve the problem but the user learnt something and can pinpoint the issue better in a report to Oneplus.
    For example...
    A CPU that has a idle activity level at the red line vs a blue line has 2 very different thermal situations. One of them may already be overheating due to a faulty app or system component. The other one is as cold as possible considering the available ambient temp.
    https://forums.oneplus.com/threads/anandtech-oneplus-9-pro.1464460/
    Some of my comments on the X1 core "trick"... New posts popping up everywhere over and over...
    My joke was over the fact that you can find 4 posts looking like this... Post no 300 somewhere for example... It's a question. 302 is the answer. 303 is the same question again... Your "bot" comment indicated that you don't feel like answers and info is needed to be given over and over again, but clearly it's needed. Even just a few posts apart sometimes.
    Caomhin likes this.
  2. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Jul 7, 2021
    Ghazala.Yasmeen , Jul 7, 2021 :
    We are sorry to hear that you are facing the issue with the device and have contacted you through direct message.
  3. Ghazala.Yasmeen
    We may have to check this further and have contacted you through personal conversation.
  4. Ghazala.Yasmeen
    We have got in touch with you through personal message, request you to check for the same.
  5. Ghazala.Yasmeen
    In order to investigate this further we've sent a direct message please check for the same.
  6. Ghazala.Yasmeen
    We understand your concern and relate to the issue you are facing and have contacted you via personal message.
  7. Ghazala.Yasmeen
  8. G_Shubham_Jaiswal_ZLEf , via OnePlus 9 Pro , Jul 7, 2021 :
    Now going follow your way let's see
  9. LeonelAioria
    Froyo Jul 7, 2021
    LeonelAioria , via OnePlus 9 Pro , Jul 7, 2021 :
    You are not the only one facing this issue, I have already submitted a report but no answer... The scrolling feels laggish, it might seem like a small detail, but it affects the experience... A LOT
    U1623243544042 and CS1989 like this.
  10. Swejuggalo
    Not extremely much though. Seen much worse happening for some.
    If closing the apps in recent apps... Does it still remain the same?
    You might be able to see hints of what happens via a battery drain analysis (either built-in stats or for example BBS and GSam). But it's far from the same as seeing a proper process overview like on a computer. We used to be able to see the exact CPU usage per process via monitor apps before but that was restricted by Google serval Android versions ago.
    What we can use however is the command "top -m 10". But even that is slightly tricky if there is no obvious major source and just many small things happening.
    If the slightly higher frequency levels is due to a high level of un-optimised system components and apps allowing a dexopt job to finish would give better performance and less drain.
    This is automatically done if connected to the charger long enough while not using the device (it usually mean longer times can be necessary than instant disconnects at 100% or 80%)
    This can be done via adb shell too without needing any changed charge patterns. "cmd package bg-dexopt-job". I can take everything from 2 minutes (not needed if so fast) to an hour or so (depending on amount of apps)
    Looking at some running processes here and do some trial and error on what happens if one of them is stopped could possibly give some hints on the source of the activity.
    Most of this is mentioned in my guide. If nothing of this makes a difference at least a few parameters is excluded. And hopefully it could lead to proof or more info of what happens if you decide to report it via the feedback tool.
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
  11. Djoon
    Eclair Jul 7, 2021
    Djoon , Jul 7, 2021 :
    the head of OnePlus and officials all use the iPhone, so they don't care about the customer and buyers to sell their hot hot dogs
    kamzee96 likes this.
  12. noexcusses
    Gingerbread Jul 7, 2021
  13. laikexpert
    Honeycomb Jul 7, 2021
    kamzee96 and noexcusses like this.
  14. Kalyani@Shete
    Cupcake Jul 7, 2021
    Gagankamboj likes this.
  15. G_Shubham_Jaiswal_ZLEf , via OnePlus 9 Pro , Jul 7, 2021 :
    Nothing happens cpu still taking much processing and battery drainage more now what?
  16. CS1989 likes this.
  17. Swejuggalo
  18. Swejuggalo
    RazvanScutea and jcae like this.
  19. kamzee96
    Honeycomb Jul 8, 2021
    kamzee96 , via OnePlus 9 Pro , Jul 8, 2021 :
    Congratulations all OnePlus 9 Pro users. Another feather in the cap apart from bugs, heating issues, severe battery drains and unresponsive dev/support team.
    Geekbench Delisted OnePlus 9 Pro from performance charts since they were caught for performance throttling. said:
    Android Police: OnePlus confirms it throttled the performance of 300 popular apps.
    https://www.androidpolice.com/2021/...ons-of-hobbling-latest-flagships-performance/
    This graph now also shows:
    1. Battery drain
    2. Oneplus user's trust
    3. Upcoming OnePlus handset sales
    4. Company's reputation
    1625715416334.jpg said:
