564
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 8, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 8, 2020 :
    On all devices with A/B partitions going back to stable from a beta usually wipes. Different on devices like 6t and older.
    rootcoors likes this.
  2. Djkam
    Donut Sep 8, 2020
  3. Djkam likes this.
  4. jsjjdbjsjd likes this.
  5. OPD
    Gingerbread Sep 8, 2020
    OPD , Sep 8, 2020 :
    Did you reproduce same issue on the MP?
  6. Batfink32
    Ice Cream Sandwich Sep 8, 2020
    Batfink32 , via OnePlus 8 Pro , Sep 8, 2020 :
    The refresh rate is auto changing (An Android 11 feature). The display refresh rate is changing from 120 to 60hz when the display isn't touched (to save battery on Android 11). Because the 8pro has different tints at 60 and 120hz, you're seeing the colour changing on grey background.
    batho likes this.
  7. sonnettie
    Froyo Sep 8, 2020
    sonnettie , Sep 8, 2020 :
    Yeah this happened to me in the stable ROM it happens when you set settings>buttons & gestures>press & hold power button to "voice assistant - google", if you put it back to "power menu" it will be normal again, hope that helps
  8. OPD
    OPD , Sep 8, 2020 :
    MP version = Stable official version
  9. P1599598257669 , via OnePlus 8 Pro , Sep 8, 2020 :
    Ok but it happens during scrolling. Is there any way to disable this feature because its really weird ?
  10. Shubham_Ag.
    Jelly Bean Sep 8, 2020
    Shubham_Ag. , via OnePlus 8 , Sep 8, 2020 :
    Try reporting this via feedback option in the profile menu of the community app!
  11. P1599598257669 , via OnePlus 8 Pro , Sep 8, 2020 :
    So you mean oxygen 10 ?
    If yes, there isnt these issues on Oxygen os 10, good size, no purple colors during scrolling, and Microsoft launcher worked correctly
  12. O1571004109615
    Cupcake Sep 8, 2020
  13. Batfink32
    Yes because you're touching the display. Touching it changes the RR to 120 not touching is 60. No,there's nothing you can do.
  14. Swejuggalo
    Play store is now finally certified.
    Netflix still says not compatible on play store and says Widevine L3.
    Google Pay not yet fully working with contact less payments.
    Will see if wiping Netflix and G-Pay makes a differance soon.
    Happy to be back on open beta. Missed is so since I switched from 7 Pro [e]1f61c[/e]
  15. Swejuggalo
    Ah... Nevermind.... Wasn't able to wait... Netflix has L1 after wiping the app [e]1f61c[/e]
