524
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. O1534861869997
    Donut Sep 13, 2020
  2. Shshank Vishwa
    Honeycomb Sep 13, 2020
  3. Shshank Vishwa
    Shshank Vishwa , via OnePlus 7 , Sep 13, 2020 :
    That I why you stick to stable release and not become test subjects for........
  4. Shijas_khs
    Cupcake Sep 13, 2020
    Shijas_khs , via OnePlus 8 , Sep 13, 2020 :
    I am facing some display issues after the update. Sometimes the display will blink several times after calls. And while using the phone at 90hrz the display will automatically adjusts the colour depth mainly in black backgrounds. Its actually little annoying. And there is also a small pink tint issue with my oneplus 8.
    Shourya_Shashank and firoz3321 like this.
  5. T1592631792508
    T1592631792508 , via OnePlus 8 , Sep 13, 2020 :
    Hi, i have installed obt update to my one plus 8 device, but i am experiencing problems while operating,
    1. Consuming much battery than before
    2. Some functions doesnt works priperly.
    Navigation bar gets hangs to often.
    Simetime a black screen appears and no operation can be done.
    Now , i want to go back to my previous version. Let me know how and will it delete all my stuff while downgrading
    Thnxx
    Ricky singh
  6. Avis786
    Avis786 , via OnePlus 8 , Sep 13, 2020 :
    The gallery is app is not updating after i downloaded pics it doesn't show in gallery ,and after switching off and switching on it shows the pics i downloaded. Please fix this
  7. Avis786
    Same is happening with me am using one plus 8
  8. firoz3321
    Froyo Sep 13, 2020
  9. Avis786
    It is almost stable bt gallery issue is still there it updates too late and games like pubg laggs
  10. YUSUFKHATRI46
  11. krish2919
    Eclair Sep 13, 2020
  12. Tee_Eee_Bee
    Ice Cream Sandwich Sep 13, 2020
    Tee_Eee_Bee , Sep 13, 2020 :
    Roll back instructions are provided in the first post. Make sure you download the correct roll back package for your device model.
    A roll back will wipe your data, so a backup prior to rolling back is a must.
    OBT to MP rollback guidevia Local OTA update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the Rollback package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. Update successful.
    Want to go back to MP? Download the Rollback package from the links below:
  13. T1592631792508
    I reside in India
    So is it IN version , right ?
  14. Tee_Eee_Bee
    I believe that is correct (I don't live in India).
  15. Inthresh
  16. T1592631792508
  17. Tee_Eee_Bee
    Isn't Google Voice only available in the US unless you are a G Suite (corporate) user?
    If you are a G Suite user, you may need to contact someone from you organisation to help you.
  18. Miraaas
    Miraaas , via OnePlus 8 Pro , Sep 13, 2020 :
    Hi, sometime in day light i can't see what is on display. So it will be good if AOD wilb be react on daylight brightness , like Samsung [e]1f44d[/e][e]1f601[/e]
  19. larsmuehlberger
  20. krish2919
    Eclair Sep 13, 2020
    krish2919 , via OnePlus 8 , Sep 13, 2020 :
    Thanks Mate!
