550
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. Rockreyad
    Cupcake Sep 13, 2020
    Rockreyad , via OnePlus 8 Pro , Sep 13, 2020 :
    I am facing this problem.its a bug!
    the notification bar is stack sometimes can't go. i minimise from game and go again same the black bar still there.
    Naman605 and AdvJaydeep like this.
  2. Arcahv
    Donut Sep 13, 2020
  3. akramansari1433
    Lehmann74 likes this.
  4. AdvJaydeep
    Donut Sep 13, 2020
  5. Sushilkpatel123456 likes this.
  6. DrearierJester1
    Eclair Sep 13, 2020
    DrearierJester1 , Sep 13, 2020 :
    has anyone managed to use Advance PDC Tool so I can enable VoLTE / VoWIFI correctly on the OOS11 Open Beta 1? The device is no longer showing on the dropdown.
  7. PoornaUmmity
  8. U1599904950514
  9. Dellusiondeny
    Donut Sep 13, 2020
    Deactivated User likes this.
  10. U1599904950514
    U1599904950514 , via OnePlus 8 Pro , Sep 13, 2020 :
    Bluetooth works incorrectly. My OnePlus 8 pro shows as it is connected to the car bluetooth, but audio can't be played. Workaround is to disconnect and then connect it manually, every time.
  11. Swejuggalo
    Community Bug Hunter Sep 13, 2020
  12. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 13, 2020 :
    Local storage/root folder/internal storage. Several names of the same thing. If you feel unsure of these things you might also want to know that regretting installing beta and want stable back will wipe the phone. The file also needs to be zip. Not zip.jar as some browsers incorrectly name the downloaded files.
  13. Swejuggalo
  14. Swejuggalo
    Yes. But you probably loose Indian specific features since it is only offered as a global firmware. Indian features may or may not come in betas later. If those are important to you wait or keep stable.
  15. nacorburgos
  16. Sushilkpatel123456 likes this.
