554
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. SteveCP
    Jelly Bean Sep 14, 2020
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 14, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 14, 2020 :
    I have seen many users having issues updating some apps. But for me none at all. Usually trial and error guide like this solves it.
    https://support.google.com/googleplay/answer/7513003?hl=en
    I use Google Play Services beta. And have updated from DP4 where I did a factory reset. Maybe some of that makes the differance.
  3. gubro
    KitKat Sep 14, 2020
    gubro , via OnePlus 8 Pro , Sep 14, 2020 :
    For the third time, OnePlus has nothing to do with it.
    The developers of the apps should make their apps compatible with Android 11.
  4. brmbjn
    Gingerbread Sep 14, 2020
    brmbjn , Sep 14, 2020 :
    this is openbeta not stable version.
    so there may be bugs.
    being friends with bugs has not been too annoying.
  5. LuminousMind
    Eclair Sep 14, 2020
    LuminousMind , via OnePlus 8 Pro , Sep 14, 2020 :
    Nice to see the blur feature in the camera (portrait mode). Google clock (digital dock) doesn't display 00:06 properly - 6 is cut off. Stable and smooth otherwise.
  6. N1593679741757
    Froyo Sep 14, 2020
  7. A1592213916494
    Cupcake Sep 14, 2020
    A1592213916494 , via OnePlus 8 , Sep 14, 2020 :
    Is anybody else not able to open the Google assistant by swiping on bottom right/left corner as well?
    It only gets opened when google keyboard is open and I swipe on the bottom right/left corner. But on the home screen or other areas, the swipe doesn't work.
    f0li0 likes this.
  8. QCIQ
  9. Knordor
    Eclair Sep 14, 2020
    Knordor , via OnePlus 8 Pro , Sep 14, 2020 :
    Yes, I have the same Problem
    f0li0 likes this.
  10. jain_chandresh1710
  11. brmbjn
    maybe you need wipe cache and wipe dalvik ...
  12. prathapchowdary
    prathapchowdary , via OnePlus 8 , Sep 14, 2020 :
    Bluetooth connectivity length decreased
    Front camera border light is not working
    Pubg is opening very slow and lagging a lot
    Speed issues
    Application crashes on some apps
    Thats all other wise phone is very good with this update
  13. Nishant0110
    Eclair Sep 14, 2020
  14. gubro
    KitKat Sep 14, 2020
    gubro , Sep 14, 2020 :
    Wrong thread.
  15. Nishant0110
    Eclair Sep 14, 2020
  16. roviou
    Donut Sep 14, 2020
  17. Jesodes
  18. L1595003005665
  19. brmbjn
    try a few days first.
    it will feel great later
