562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. ChristianHeilos
    Honeycomb Sep 17, 2020
    ChristianHeilos , Sep 17, 2020 :
    Barclays, Santander, Tesco, Monzo, Starling and Paypal
    kbszh123 likes this.
  2. ChristianHeilos
  3. ChristianHeilos
    Might be an issue specific to those apps then. Have you checked with the vendor if they are Android 11 compatible?
  4. ChristianHeilos
    If you search in this thread you will find a workaround
    gubro likes this.
  5. ChristianHeilos
    If you search in this thread, you will find the solution
    gubro likes this.
  6. gubro
    KitKat Sep 17, 2020
    gubro , Sep 17, 2020 :
    Brave.
  7. ChristianHeilos
  8. gubro
    KitKat Sep 17, 2020
    It will come when it is ready.
  9. ChristianHeilos
    My alarms are working fine
  10. ChristianHeilos
    You will have to wait a bit longer...
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 17, 2020
  12. gubro
    KitKat Sep 17, 2020
    LOL
    Learn how to tag people properly.
    Besides I doubt Gary speaks your language.
    I'm guessing the 7T in your comment means you are asking for the OOS11 for that device. OnePlus never gives timelines for these updates. It will come, when it is ready, and certainly not before the 8 series reached stable, so definitely months away.
  13. gubro
    KitKat Sep 17, 2020
    Don't hold your breath.
  14. Rryuk
    Froyo Sep 17, 2020
  15. k4ustu3h
    Froyo Sep 17, 2020
  16. gubro
    KitKat Sep 17, 2020
    Oneplus does not communicate about timelines.
  17. FlugzeugSK
    FlugzeugSK , Sep 17, 2020 :
    i first installed DP3, without issues, then updated to DP4 with full package without issue (i have only wiped cache).
    it hapened first time, i was not able to replicate this issue...
    i have done reset of the Unit and everything goes well.
    when OB1 cames out, i have done clean install and clean manual setup without restoring any data..
    it happened again then, unfortunately i have no time and space to play with this around :-(
    so i reverted back to stable OOS10 and will wait for next BETA update...
    Swejuggalo likes this.
  18. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    Thanks for the info
  19. Mark Falsing
    Moderator Moderator Sep 17, 2020
  20. gubro
    KitKat Sep 17, 2020
    It is surprisingly stable for being a first beta. You will like it :)
    Mark Falsing and razorrahul like this.
