562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 17, 2020
    Liehjan , Sep 17, 2020 :
    When all bugs are ironed out, expect 3-4 open beta builds before the stable...
    Caoimhín and RobertEduard01 like this.
  2. Mike_N
    Cupcake Sep 17, 2020
  3. Thejainn
    Thejainn , via OnePlus 7T , Sep 17, 2020 :
    @gubro , I wonder why humans have this craving to correct other fellows. and that leaving all your daily chores you thought it would be wise to advice me. well I certainly will take a sec. to thank and appreciate your effort. The sarcasm was certainly lost on you. 🙂
  4. gubro
    KitKat Sep 17, 2020
    gubro , Sep 17, 2020 :
    Unlike you I actually answered the question. Your aim was only to show off. Well done.
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 17, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    I've seen someone recommending manual update of Play Store. Maybe it's a specific Play Store build that is troublesome. Seen it happen on 7 series with 10 too.
    The easiest test would probably be to wipe data of Play Store and uninstall updates.
    Mike_N likes this.
  6. Sachin Hosalikar
  7. Kaitsu1991
    Kaitsu1991 , via OnePlus 8 Pro , Sep 17, 2020 :
    My banking app that is the one I use to verify my identity in many apps/sites does not work after downloading Android 11. I was so desperate to try to downgrade back to the old android but doing so will factory reset my phone. This is really bad since I really cant do the reset but I really need that app working.
  8. U1579080210139
  9. G_Dheeraj_Mandal_zGpk , via OnePlus 8 Pro , Sep 17, 2020 :
    Actually now i am back to stable version of Android 10 coz in this Android 11 green tint is like everywhere with various bugs like warp charging won't work and the battery backup is poor and heating up for no reason!
  10. f0li0
    Gingerbread Sep 17, 2020
    f0li0 , via OnePlus 8 Pro , Sep 17, 2020 :
    My favourite thing about OOS 11 OB is the white fingerprint sensor. The green one messed up my theming, even if it was only for a brief second. In fact the theming overall is nice, I was one of the ones against the new look in the beginning but after running it for nearly a week, I love it.
    yannickalibay likes this.
  11. Reft_W
    Eclair Sep 17, 2020
  12. Swejuggalo
    Dominic_Huang likes this.
  13. APhaniSankara
  14. RKO8726
    Donut Sep 17, 2020
  15. Swejuggalo
  16. abhi_lodhi
    Eclair Sep 17, 2020
  17. dyran1017
    dyran1017 , via OnePlus 8 , Sep 17, 2020 :
    Hi guys, does anyone experience not able to make calls and receive calls on your phones ? When I updated Beta , I cannot make calls and even receive calls, but I can receive SMS. I tried changing setup on CALL SETTINGS, like call barring etc.. but cannot edit and showing error.. like this
    I tried swappimg my simcards to my other phone and it does work , can make calls and receive calls, so that makes me conclude there is some problem on my Oneplus 8.
    Any inputs will be helpful
  18. k4ustu3h
    Froyo Sep 17, 2020
