562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. gubro
    KitKat Sep 17, 2020
    gubro , Sep 17, 2020 :
    When you are sound asleep and dreaming.
    SteveCP likes this.
  2. k4ustu3h
    Froyo Sep 17, 2020
    k4ustu3h , via OnePlus 8 , Sep 17, 2020 :
    You shouldn't use "beta" and "without bugs" in the same sentence, it's forbidden.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 17, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    Beta 2 is bug free? [e]1f61c[/e]
    Seriously though... Beta update schedual is normally 1 update per month.
    Beta is beta for a reason. For testing stuff and reporting bugs to make the software better and fix bugs in new features before they enter a stable firmware. Bugs are to be expected in a much higher degree than stable.
    FlugzeugSK, SteveCP and AButton117 like this.
  4. Naveen Kella
    Cupcake Sep 17, 2020
  5. A1599841966493
    A1599841966493 , Sep 17, 2020 :
    So, I am trying to install the OxygenOS 11 open beta. I have followed the instructions and I can't get it to install. I suspect it's because I don't have root access, but I didn't see any mention of needing root access to install it. I have the install file moved to the highest level directory I have access to without root access, but when I try to run it I get the message in the second screen.
  6. Swejuggalo
    A hint. It's a zip file. Is it really a zip file? [e]1f609[/e]
    Just hope you know the risks of beta and that later returning to stable will wipe the phone.
  7. Marek_Orovnicky , via OnePlus 7 Pro Nebula Blue , Sep 17, 2020 :
    you need to remove .jar extension at the end and move to the root directory
    Naveen Kella likes this.
  8. Swejuggalo
    The instructions said nothing about extracting the file.
  9. bradb21
    bradb21 , Sep 17, 2020 :
    All I had to do was to download the file and make sure you copy it to the ROOT of the file system.
    This is also not for carrier locked phones
  10. C1588077335071 , via OnePlus 8 T-Mobile , Sep 17, 2020 :
    hello. question: what exactly did you do to install it? it downloads to My Drive after I click the link provided..but when I go to system update... there is nothing to click in the top right corner(as stated in the instructions above). where do I find local update? because all I can see is, "check for update." am I doing something wrong?
  11. gubro
    KitKat Sep 17, 2020
    Yes. The answer is right above your question. On this very page.
    C1588077335071 likes this.
  12. A1599841966493
    Yes, I extracted the file and placed the .bin in the highest level directory that I have access to. Also, my phone should be unlocked at AT&T is my carrier. As I understand it, only T-Mobile and Verizon have carrier locked phones.
  13. SteveCP
    Jelly Bean Sep 17, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 17, 2020 :
    Works in Nova no issues
  14. Molceanov
    Molceanov , via OnePlus 8 Pro , Sep 17, 2020 :
    I don't use auto update
  15. k4ustu3h
    Froyo Sep 17, 2020
    YOU DON'T NEED TO EXTRACT THE ZIP FILE. You need to move the zip itself in internal storage. And you don't need to have root access to install the update.
  16. SteveCP
    gubro likes this.
  17. SteveCP
    Not trying hard enough or reading the posts that solve your issue. Stick to OTA downloads and do us all a favour.
  18. SteveCP
    Shouldn't be a .bin file but obviously since you have seen 2000 other threads telling you how it should be named already I am sure you already knew that. Read the posts instead of posting shite
  19. sonhawk
    Froyo Sep 17, 2020
    sonhawk , Sep 17, 2020 :
    In the screen shot you posted, it says "Auto-update is turned on". Based on that, you did use it when you captured the screenshot of your problem. But whatever you say... :confused:
    SteveCP likes this.
