550
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. gubro
    KitKat Sep 18, 2020
    gubro , Sep 18, 2020 :
    Never
  2. Swejuggalo
    Community Bug Hunter Sep 18, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 18, 2020 :
    If you can replicate this please try to go into the proper cathergory in the feedback tool, start a recording, replicate, leave area, stop recording. Send in the logs with carrier names and error description. Hopefully that leads to a solution.
  3. gubro
    KitKat Sep 18, 2020
    I'm on Vodafone, 5G works fine.
  4. Rejbrighouse
    Froyo Sep 18, 2020
  5. Toni Merikanto
    Gingerbread Sep 18, 2020
    Toni Merikanto , Sep 18, 2020 :
    There is also a feedback tool in this website under support menu. If you don't wanna use tha oneplus app or when it just doesn't load.
  6. Swejuggalo
    The downside is that you can not create that log file the community app can do.
  7. naheedmir
    naheedmir , Sep 18, 2020 :
    Hi Jasonew,
    Weldone! I also have the same view. Instead of frowning on one or the other, we must focus to resolve the issue and see where we can find the batter solution. Your words reflect you entirely. So batter to use the forums for healthy discussios.
    A professional and comprehensive discussion is important everywhere. You explained well.
  8. xAn0nYm3x
    Froyo Sep 18, 2020
  9. darren190390
  10. ChristianHeilos
    Honeycomb Sep 18, 2020
    ChristianHeilos , Sep 18, 2020 :
    I'm on Version 21.8.19-21 [0] [PR] 330823897
    I think it might be the file size... Now the Microsoft Office can't be updated either using Play Store
  11. G_Suvankar_Ghosh
    Eclair Sep 18, 2020
  12. G_Suvankar_Ghosh
    Eclair Sep 18, 2020
  13. Toni Merikanto
    Logfile can be created without the community app too, allthough it is easier from that.
  14. Swejuggalo
    Same as me then.
    A other possibility. Play Store Services.
  15. ChristianHeilos
  16. Swejuggalo
  17. Swejuggalo
