562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 18, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 18, 2020 :
    Could be regional rollouts. Pretty common even on apps in Play Store. Perhaps the reason lies in Play Store version... But some say they tried uninstalling updates of it with no luck.
    Annoying not to be able to replicate the issue.
  2. J1577168162931
    Cupcake Sep 18, 2020
  3. Jona V.
    Gingerbread Sep 18, 2020
  4. SteveCP
    Jelly Bean Sep 18, 2020
    gubro and ChristianHeilos like this.
  5. k4ustu3h
    Froyo Sep 18, 2020
    k4ustu3h , via OnePlus 8 , Sep 18, 2020 :
    Rename the file and remove the .jar at the end
    ChristianHeilos likes this.
  6. ChristianHeilos
    Honeycomb Sep 18, 2020
    ChristianHeilos , Sep 18, 2020 :
    Tried that too, including clearing the cache and storage... It just seem odd this larger updates seem to fail.
  7. ChristianHeilos
    It's not half bad!
    Jona V. likes this.
  8. jshanaa
    Eclair Sep 19, 2020
  9. LuvzMobile
    Donut Sep 19, 2020
    LuvzMobile , Sep 19, 2020 :
    can someone confirm the rollback version I use.
    Bought in US from one plus site
    model IN2025
  10. LuvzMobile
    Donut Sep 19, 2020
    Thank You!
  11. SaiDepp
    Donut Sep 19, 2020
  12. Ripon81
    Donut Sep 19, 2020
    Ripon81 , via OnePlus 8 , Sep 19, 2020 :
    OnePlus 8 nightscape mode makes me disappointed [e]1f622[/e]
    Please improve nightscape photo quality [e]1f64f[/e][e]1f64f[/e][e]1f64f[/e]
    V1595501874221 and OmarRolon like this.
  13. Rob.S
    Cupcake Sep 19, 2020
  14. Tee_Eee_Bee
    Ice Cream Sandwich Sep 19, 2020
    Tee_Eee_Bee , Sep 19, 2020 :
    If you want to install the A11 Open Beta 1, you need to do it manually - see the first post for instructions.
    The timeframe (although not guaranteed) given for a stable release is October, and this may be available via OTA.
    Also, please be aware that if you are using a T-Mobile branded device, T-Mobile have their own release schedule that is different to OnePlus. You can change this if you convert your device to a global model, a google search will show you the instructions for this.
  15. razorrahul1
    Gingerbread Sep 19, 2020
    razorrahul1 , via OnePlus 8 Pro , Sep 19, 2020 :
    Move the downloaded file from download folder to internal storage. Then it'll be visible
  16. Pritesh0944
    Pritesh0944 , via OnePlus 8 Pro , Sep 19, 2020 :
    Sir can u help me ? I bought oneplus 8pro on 28 july 2020 from croma mumbai , n jst after 15 days i m facing charging issues , phone charges but the percentage not showing correctly , sometimes it shows normally otherwise it stucks at certain percentages and after that phone keeps charge , also shows charging indicator but the charging percentage not increase nor decrease , it stucks on certain percentages. I also showed to the authorized service centre , they just format everything n give it back to me , can it is software issue that will solve from next update ? Sir plz suggest me cz i bought it n 55k is worths me a lot , plz sir help me if u can , thank you
