564
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. jasperjunnu
    Froyo Sep 21, 2020
  2. ErynOP
    Gingerbread Sep 21, 2020
    jasperjunnu likes this.
  3. Funk Wizard
    Moderator Moderator Sep 21, 2020
    Funk Wizard , Sep 21, 2020 :
    Check the right build tag for your device from the download page and try again
    S1589526000059 likes this.
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 21, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 21, 2020 :
    The only real way to know is to try it yourself and compare. With my usage and chosen settings it can be everything between 6-10h+ SoT. I haven't really done a proper idle drain test on 10 nor 11 so I can't really compare it. I can't really say if total battery life is better or worse than 10 either. Average might be fairly similar.
    But I'd say it's a higher risk of compability issues and poorly behaving apps on 11 simply due to the apps does not support 11 fully and due to the possible issues that comes with Oxygen OS 11. In short results may vary.
  5. SteveCP
    Jelly Bean Sep 21, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 21, 2020 :
    Only those that haven't clicked the global firmware and instead have downloaded the rollback software
  6. SteveCP
    There is no build download unless it is for the rollback firmware, it's a global firmware, not compatible with carrier locked US phones.
  7. gubro
    KitKat Sep 21, 2020
    gubro , Sep 21, 2020 :
    Duo works fine for me.
  8. Funk Wizard
  9. SteveCP
    Correct tag, you advised someone to make sure they were downloading the correct build.... It's a global forward not regional so only has one possible build.
    That being said the OP could be a mong and tried to download the 8pro build for the 8.
  10. Funk Wizard
    Funk Wizard , via OnePlus 8 Pro Ultramarine Blue , Sep 21, 2020 :
    Oh yeah I shouldn't have use the word tag, I meant the correct build for the device 8/pro, hopefully the user got it right.
    SteveCP likes this.
  11. ArifAlshamad
    Donut Sep 21, 2020
    ArifAlshamad , via OnePlus 8 Pro , Sep 21, 2020 :
    1. Always on display is too bright compare to samsung,
    2. clock timing showing only 24hrs we cant change to 12hrs,
    3. always on display consuming battery health
    4. While device connected with wifi means call quality is too bad, i need to turn off the wifi to speak.
    Alex_010911 likes this.
  12. 1bigapp
    Cupcake Sep 21, 2020
    1bigapp , Sep 21, 2020 :
    Would love to see Google Phone app with Spam Filter. OnePlus Team, please, that's not so hard :)
    Kmoney059 likes this.
  13. SteveCP
    Download it if you want it, there is a beta that is compatible with OP phones, I am running it along with others on here.
    Swejuggalo likes this.
  14. Swejuggalo
    SteveCP likes this.
  15. subinkoshyjohn
  16. Swejuggalo
    4. Can't you just use WiFi calling with calling over mobile network as standard? The only point with VoWiFi as I see it is to use it when mobile network does not have a connection. It automatically uses VoWiFi if needed. Then it is used only as a last resort. So no need to turn of WiFi.
  17. JoseReyes69
  18. Swejuggalo
