554
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. drmartin
    Moderator Moderator Sep 22, 2020
    drmartin , Sep 22, 2020 :
    The first rule of fight club is not to ask about update estimates. :)
    Djkam likes this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 22, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 22, 2020 :
    Probably possible to tweak some. Problem is the pretty wide variation of issues with screen. If someone have pretty ok 60Hz black and Grays and someone really bad... They can't make it exactly the same for both.
    A way to hide that a bit would be incremental slow switch from 60Hz to 90/120Hz. But that means it must work in driver and hardware level.
  3. jasperjunnu
    Froyo Sep 22, 2020
    jasperjunnu , via OnePlus 8 Pro , Sep 22, 2020 :
    I have already tried os11 DP but had to roll back to os10 because of fast batterie drain issue.
  4. Swejuggalo
    How many days did you try? You would probably get better experiance from a clean install and approx 3+ days usage.
    I'd recommend BetterBatteryStats to learn the behavior of the drain.
    Only tweaks I've done are the use of AutoHz app, disable bluetooth background scanning, enable WiFi mulit/broadcasting filter Optimize on apps I rarely use. All other on Intelligent expect the ones that needa to be on Not Optimize. Bluetooth on at demand and everything else always on. No special routines to preserve battery. Charging every night.
    I also use Web apps when possible instead of the actual app.
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
  5. Tonyatme
    Froyo Sep 22, 2020
    Tonyatme , via OnePlus 8 Pro , Sep 22, 2020 :
    Questions from our users about Beta 1
    1. Too much software, sometimes the desktop is often unresponsive
    2. When the fingerprint is unlocked, sometimes there will be no response or the interface will be unlocked from the desktop
    3. The phone will sometimes show that the temperature is too high when not in use, which will reduce its performance or slow response when it is used again.
    4. The color of the camera will be displayed in other colors in some situations
    5.5G signal support. In Hong Kong, N1 (2100 MHz), N78 (3.3GHz and 3.5GHz) network spectrums are mainly used. However, from the first version of the system to the current beta version, I have not been able to see it. Receive 5G.
    6 (Note: Actual network and frequency band usage depends on local operator deployment. n1,n3,n7,n28 will be supported later through upgrades), this will not come until when.
    7A 5G mobile phone cannot use 5G, so we need to become a 4G mobile phone
    8. In the multitasking background, can you add the ram display and let us know how much ram is used?
    9. OnePlus Wallet cannot be used in the international version.
    10. The fonts in the phone are not open, and you cannot add your favorite fonts by yourself.
    11. The gallery reacted too slowly when deleting photos.
    12. Power saving problem, sometimes the power will be cut off quickly, sometimes it is normal.
    Problems found temporarily.
    AdvJaydeep likes this.
  6. Swejuggalo
    Tokolozi likes this.
  7. shubham_117
    Froyo Sep 22, 2020
  8. FlugzeugSK
    Honeycomb Sep 22, 2020
    FlugzeugSK , Sep 22, 2020 :
    it will come when it is ready. :)
    some say that 14.10. with the introducing of 8T, some say it will be released later...
    shubham_117 and gubro like this.
  9. galza
    Cupcake Sep 22, 2020
    galza , Sep 22, 2020 :
    I think near the 14 of october because 8t will come with stable 11..
    shubham_117 likes this.
  10. KNbG
    Froyo Sep 22, 2020
  11. LuvzMobile
    Donut Sep 22, 2020
    LuvzMobile , via OnePlus 8 Pro , Sep 22, 2020 :
    Device = OP8PRO
    Model- in2020
    Carrier- Mint mobile
    Beta 1
    Google Messages
    Sending messages and pictures- works fine
    Receiving messages and pictures- takes 5- 10 minutes if at all
    Done to try and resolve(not necessarily in this order)
    Reset network settings
    Clear cache
    Clear storage
    Turned off battery optimization
    Done for both Google Messages and carrier services
    Double check apn settings
    Reset entire phone
    I finally rolled back [e]1f612[/e] but really loved it otherwise
    I get its beta software just wondering if anyone shared this issue
    Thank you
    Scott
  12. SandeshChinchapur
    Jelly Bean Sep 22, 2020
    SandeshChinchapur , Sep 22, 2020 :
    Why do they had to change the layout of pictures? This layout in Open beta looks way simple compared to Dev preview.
    Dev preview
    Open Beta
  13. Last edited by a moderator: Sep 22, 2020
  14. pwner525
    Cupcake Sep 23, 2020
  15. Tee_Eee_Bee
    Ice Cream Sandwich Sep 23, 2020
    Tee_Eee_Bee , Sep 23, 2020 :
    If you are trying to open the links in the community app, try using the 3 button menu to open in your browser.
  16. x_biff
    Eclair Sep 23, 2020
  17. brmbjn
    Gingerbread Sep 23, 2020
    brmbjn , Sep 23, 2020 :
    I hope that Oneplus will provide the photocromic camera features again in the next update ...
  18. Gowda.kakanna
    Gowda.kakanna , via OnePlus 8 , Sep 23, 2020 :
    Is 8 will support wireless charging?
  19. Gowda.kakanna
