564
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. 5fq
    Cupcake Sep 25, 2020
  2. leekimah
    Cupcake Sep 26, 2020
    leekimah , via OnePlus 8 , Sep 26, 2020 :
    I really like it overall..
    But I have noticed some bugs, which are very annoying.
    1. Beta 1 or 2, My fingerprint scanner sometimes lagged when I pressed it during unlocking, sometimes screen turns to black. pressing power button wont help. It would sometimes lead to an automatic restart.
    2. Beta 1 or 2, My keyboard turns to completely white, you can still type but you cant see the letters. The only way to return it to normal is to swipe home and open the keyboard
    3. On open beta 2, I have noticed that the back button sometimes wont work, swiping home button helps
    4. Beta 2, I have recently encountered keyboard not popping up, It was specifically on the AmongUs game, but happened only on beta 2
    Please take note that I didnt experience these on stable. Thanks
  3. Krish369
  4. Gowda.kakanna
    Eclair Sep 26, 2020
  5. deadpool3049
    deadpool3049 , via OnePlus 8 , Sep 26, 2020 :
    The only thing I can suggest is to reset your phone that seems to work
  6. efks
    Ice Cream Sandwich Sep 26, 2020
    efks , Sep 26, 2020 :
    Due google services something with media servers which keep awake cpu at hight clock speed. Disable playstore for some days they push new update
  7. angelarge03
    angelarge03 , via OnePlus 8 Pro , Sep 26, 2020 :
    I have uninstalled it but the canvas ambient display is still there. Annoying.
    evnsriram likes this.
  8. angelarge03 and evnsriram like this.
  9. evnsriram
    Eclair Sep 26, 2020
    evnsriram , via OnePlus 8 , Sep 26, 2020 :
    This in fact solves the issue and even enables the option to turn on always on display. Thanks for the tip. You have a good day!
    angelarge03 and Deactivated User like this.
  10. evnsriram
    Eclair Sep 26, 2020
    Please check the tip from Jason above.
  11. W1600295113235
    W1600295113235 , Sep 26, 2020 :
    Hey guys, I can't install update OnePlus Gallery to my OnePlus 8 Pro. Currently I'm using Beta 2 build.
    angelarge03 and jshanaa like this.
  12. k4ustu3h
    Froyo Sep 26, 2020
  13. Azbulldog
    Cupcake Sep 27, 2020
    Azbulldog , Sep 27, 2020 :
    Thank you but there is already ample information on how to find the option, that doesn't help the fact that it is not shown on the far left.
    [​IMG] [​IMG] [​IMG]
  14. X1601182033822
  15. A.R.Anandhu_Avk
  16. X1601182033822
  17. Toni Merikanto
    Gingerbread Sep 27, 2020
    Toni Merikanto , Sep 27, 2020 :
    Yes. It is a beta. Some users have more others have less bugs.
