562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. A.R.Anandhu_Avk
    Cupcake Sep 27, 2020
  2. Alokpanda
    Alokpanda , via OnePlus 8 , Sep 27, 2020 :
    Because of soo many bugs i want to downgrade to original version not the beata version
    Can u tell me how to down grade that it is not accepting that
    angelarge03 likes this.
  3. k4ustu3h
    Froyo Sep 27, 2020
  4. Tee_Eee_Bee
    Ice Cream Sandwich Sep 27, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Sep 27, 2020 :
    Make sure you follow the instructions in the first post and also download the correct version for your device/region. Also, as stated in the instructions, roll back will wipe your device, so back everything up first.
    Note: OBT is open beta, MP is Android 10
    OBT to MP rollback guide—via Local OTA update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the Rollback package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. Update successful.
    Want to go back to MP? Download the Rollback package from the links below:
    Download links for OnePlus 8:
    OnePlus 8 NA Version
    OnePlus 8 IN Version
    OnePlus 8 EU Version
    Download links for OnePlus 8 Pro:
    OnePlus 8 Pro NA Version
    OnePlus 8 Pro IN Version
    OnePlus 8 Pro EU Version
    G1596863877316 likes this.
  5. A.R.Anandhu_Avk
    Cupcake Sep 28, 2020
  6. H1575333417663
  7. Tee_Eee_Bee
    Ice Cream Sandwich Sep 28, 2020
  8. Toni Merikanto
    Gingerbread Sep 28, 2020
  9. angelarge03
  10. Nathanael Teddy Backhouse
    Eclair Sep 28, 2020
    Nathanael Teddy Backhouse , Sep 28, 2020 :
    Hi there, I’m using a Oneplus 8 and have tried beta 1 and now on beta 2. Mostly pretty stable but the biggest issue has been Swiftkey and also Gboard freezing when typing in various fields...especially address bar on Edge. Clearing all apps and starting Edge again fixes it, but it’s been happening for a few days. I’m using Ratio launcher which I couldn’t get to be the default home app on Beta 1 in first day or two of use, but since day 2 or 3 has been running fine. Beta 2 no problems using Ratio as default launcher.
  11. Nathanael Teddy Backhouse
    Eclair Sep 28, 2020
    I want to go back to MP official build (Android 10) due to above mentioned issues with keyboard. Have done factory reset, downloaded the rollback package and tried to do local install but no joy. Message says I’m not allowed to rollback to an older rom.
  12. Tee_Eee_Bee
    Ice Cream Sandwich Sep 29, 2020
    Tee_Eee_Bee , Sep 29, 2020 :
    Did you download the rollback package or the android 10 software from the support page?
    Looks like the roll back package download links are not working at the moment. I can't even get external links to work.
    Edit: The links work in the community app, just not on my laptop.
    If they don't appear to be working, tap on the 3 dots in the top right hand corner and tap "Open with browser" and it should download.
  13. G1592674411026
    Cupcake Sep 29, 2020
  14. Nathanael Teddy Backhouse , via OnePlus 8 , Sep 29, 2020 :
    The .Jar file is downloading fine, I copy it from downloads folder to a level above under internal storage, and then try and install via local upgrade...now it just says "move installation package into root directory" but it is there ....not in any folder. Not sure what's going on.
  15. k4ustu3h
    Froyo Sep 29, 2020
    k4ustu3h , via OnePlus 8 , Sep 29, 2020 :
    Rename the file and remove the .jar at the ending.
  16. Milzz
    Eclair Sep 29, 2020
    Milzz , via OnePlus Nord , Sep 29, 2020 :
    Please Change Camera Watermark Style of Shot on OnePlus Nord In OnePlus nord like other OnePlus device
    and please Change incoming calls Screen of OnePlus Nord Like other OnePlus Device Like 7 and 7T
    please Sir i m big fan of OnePlus Camera but Please Update Watermark style of OnePlus Camera like other OnePlus device like 7 & 7T
    and There is Problem in OnePlus Nord in Network Issues
    we Can't Get Enough Internet Speed in OnePlus Nord and Covrage Problem also...
    Thank you
  17. alikais9
    alikais9 , Sep 29, 2020 :
    I'm using Open Beta 2 and I'm experiencing that the files load slowly in the gallery app and file manager. Is there anyone else having the same problem?
  18. Nathanael Teddy Backhouse
    Eclair Sep 29, 2020
    Nathanael Teddy Backhouse , Sep 29, 2020 :
    Wondered if .jar was the right format....your solution worked. Thanks!
  19. nikem154
